New member Username: DiesielPost Number: 4 Registered: Jun-06 | Hi guys i have a Pantec Receiver, Which Loader do i need to update the Bin? Thx. |
Silver Member Username: WakenbakePost Number: 204 Registered: Mar-06 | do you have the bin get loader @same site |
Gold Member Username: LklivesPost Number: 3448 Registered: Jan-06 | whatever works...take your pick of about 20 of them for pansat bins! |
New member Username: DiesielPost Number: 5 Registered: Jun-06 | Ok i have Pantec Ultra V1 (just found the box) If someone can give me Safe Bin/Loader to diesiel@gmail.com I would be VERY greatfull. |
Bronze Member Username: BthitmanPost Number: 17 Registered: Jun-06 | LK you sound as though you're frustrated with these same old questions ? LOL. |
New member Username: DiesielPost Number: 6 Registered: Jun-06 | Well the reason i ask is becuase i am using the Blacklist STB updated with the 277T Bin (said its safe for clones) but i am ALWAYS getting the write failed error (i am following Nicks guide). I am starting to beleive maybe the cable doesn't work or something... |
Bronze Member Username: BthitmanPost Number: 18 Registered: Jun-06 | adbe, are you using a straight data cable ? Or does it have a node inline ? |
Silver Member Username: The_wank_artistPost Number: 932 Registered: Feb-06 | Take LKs advice and try a different loader. We've seen lots of people with the same issue these past few days and though it makes no sense, different loader work where others did not. |
New member Username: DiesielPost Number: 7 Registered: Jun-06 | Yes i beleive now it is the cable's issue. It is Apparnetly A Cross over (Null) cable and i need a Straight through cable, I shall replace it tomorow, thank you for advice guys. P.S i have used many of the loaders, still same result. |
