Flash Failed to Update any suggestions?
Username: Big_easy
Starting Over, I just bought new Null cables yesterday at a local computer store and tried to download the latest Bin file to my Ariza 700. When I do I continue to get an message saying Flash Update Failed. I have gone to ftacentral, re download the loader for the Ariza 700. I am not using a usb port. Is there anyway to test the NULL cable to see if this is my problem. Any suggestions to trouble shoot would be appreciated.JD.
Username: Evadelparaiso
Puerto Rico
Post Number: 1005
What you need:
RS232 NULL Modem cable (CROSS OVER TYPE)
STEPS:
1) Download the STB Downloader and the patch file for the ARIZA 700 or the 750
depending on the receiver you own.
* ARIZA 7XX loader v4.03>>>>>>>>>>>>>>>>> Is the Downloader for 700 & 750
I mean your cable its not the right cable.
Username: Big_easy
Post Number: 7
Thanks to all that replied to my thread. Everything has been sorted out and we are up and running.
Puerto Rico
Post Number: 1028
you welcome
