I was going to cut and paste only the important stuff, but i see that most of the stuff can be useful to those who are willing to learn by reading.. I dont know if this was posted previously... if it was, well---there is a lot of info posted and reposted any how.. C/p
Friends are like a head of hair. You might lose some but with enough money you can buy them back.
277t has Auto-Key & Auto-TP-Roll & Bev, Safe For All Fortec Lifetime Ultra Clone's & Pansat 2500a. This is NTSC not PAL Read all of these instructions and you will have less questions and may learn something. TP auto-roll will find a channel if it is moved. It will NOT find the channel if it moves to another Satellite.
PLEASE DO NOT PM ME WITH QUESTIONS, POST YOUR QUESTION IN A NEW THREAD.
YOU CAN PRINT THIS OUT IF YOU LIKE To print this out in a printable version go close to the top of this thread and click on THREAD TOOLS then click on SHOW PRINTABLE VERSION then click on PRINT in your browser.
I am NOT taking credit for this bin just the instructions. Chancysand & others get the bin credit.
PLUGGING IN CABLE. Make sure you plug in the cable from the dish to the receiver at the IF 13/18v INPUT. Not the ANT IN. Also the wires coming from the dish to the switch should be put on the switch at the same number as you have set in your receiver. Like 119 wire goes on number 1 on the diseqc switch and the receiver has #1 for 119 in the program.
HOW TO FLASH FORTEC LIFETIME ULTRA. You can flash (load) your Ultra with this bin on top of the bin (file) you already have. It will replace it. Use a STRAIGHT THROUGH CABLE RS232C hooked up to your receiver from the computer. Take the cable off going to the LNB to be safe. If you have the year model Dec 2004 or newer you can clone it or you MAY need to use a USB to Serial cable 26-183 at Radio Shack. Get detailed instructions about the cable here http://www.ftahome.com/ Satellite Finder Web Sight. A program that will let you know where to point your dish for a Satellite. http://www.nerosoft.com/SatCalcView.asp J-TRACK SHOWING POSITION OF SATELLITES http://www.selkirkshire.demon.co.uk/...ingdishes.html
TO CLEAN AND PUT LUBRICANT ON YOUR REMOTE TO WORK BETTER. Use ProGold G100P from Radio Shack part number 64-4337
