Pioneer Premier Subs
Username: Tiggerboi87
Pensacola, FL United States
Post Number: 29
Are these a good subs. I see that they are pretty cheap and that many of the reviews that i have read on them say that they are very good.
Username: Ctmike
Ct.
Post Number: 840
there pretty cheap cause there pretty sh!tty.
Post Number: 32
ok
Username: Rovin
Trinidad & T...
Post Number: 8172
i should be able 2 tell u about them in about a wk's time cause my buddy (with partitial specs advice from me) is putting 8 12s 3002 series 1000wrms each in a station wagon - but i expect them 2 hit hard .....
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 240
There was a guy at a local sound comp here that had 8 12 Pioneer premier. Its sounded pretty loud and not to horrible on sq. Then agian though almost any 8 12's can be loud right.
Username: Alteraudiousa
Concord
Post Number: 940
The tws3000 and tws5000 IIRC the model correctly are pretty stout subs...output will decent on them and SQ is ok. There are others better but if you can get a good price it'll give alot of audible output.
Username: Econoline1
Vancity, Bc Canada eh
Post Number: 46
pioneer premier broke spl world record @ 180.5 dbs
THIS IS A COMPITION SUB. NOT A STREET SUB.
this sub has no sq. It is all spl.
the voice coil heats up really fast and is not ment for continous daily play.
I have had lots of experiance with this sub
for the price it is good i guess.
Username: Usask8er1
Post Number: 245
Thats awesome and all but i dont think tigger was ever talking about this sub. I figured when he said cheap he was talking about the lower end premier stuff. We all know the subs ur talking about or crazy.
Post Number: 48
well they do make a toned down version of "the record breaker" runs about $250. This is cheap compared to my 13w7.
Username: Usask8er1
Post Number: 247
I love how u had to throw in compared to your 13w7 lol. My buddys got one and when ever he talks about a system he ends it with "compared to my 13w7" What you use to power yours by the way?
Username: Jonez788
Post Number: 164
I have the 3004SPLs. They are very good. They're not JUST SPL. They have a good amount of sound quality to them. They were recommneded to me by a very reputatble local shop.
Don't be fooled by the cheap price on them. They are very well made.
Post Number: 51
1000/1. no jk. I actually went with pioneer to sttart. bought rps3000spl amp and 12" 3002spl sub.
burnt voice coil on both wasnt loud enough.
i am using the premier amp to power it @ 1000rms 3ohms.
not optimum but still very good.
