New member Username: Westy79Post Number: 1 Registered: Jun-06 | i have bought a samsung lcd 32" hdtv. when i watch my cable(telewest in the united kingdom) the picture is pixelated. When i watch a dvd it looks great and hd channels look superb, is it to do with the cables as they are only standard or are there any settings i can make. its a bit disapointing as i have just paid over £1100 for the tv. also my tv only has on hd socket so whats the best way to connect my dvd recorder to enable the best picture. |
Bronze Member Username: EhdmiPost Number: 48 Registered: Mar-06 | Unfortuantely, SD channels aren't going to look that great. You can try better cables, they may help alittle. They will help on HD. Keith http://www.eHDMI.com |
