Pansat 2700a
Username: Bugster999
Katy, Tx
Post Number: 7
Woke up this morning and what did fine all my channels are scrambled will a blind scan do the the trick or did something happen last night. I see the keys are the same just wondering.
Username: Donnie1973
Post Number: 26
Hasnt changed yet. Mine is up.
Username: Lklives
Post Number: 3464
Do a receiver REBOOT...Back of receiver, power OFF for 3-4 minutes, power ON, turn to channel 300..
Post Number: 28
LK, is this just a glitch in the bin?
Username: Lklives
Post Number: 3467
its common...I call it a hiccup!
Username: Overthehill
Post Number: 14
I have seen the same with this bin and others in the past. Yes, a cold start will do it. I even saw my receiver turned off by itself once when scrambling. But it is not too bad, after a power off/on, it works fine and this is actually not happening often.
Username: Ousu
Hello
I woke up also this morning but with only
some of my channels on specific frequencies
NO SIGNAL
I powered the pansat 2700A off and on again
but no signal still
The dish is still aimed the same way.
for example on echo 19/3 I am getting
0% quality oonn freq 11768 H while i am getting
good qyuality on other freqs.
What could be the problem Please??
Thanks
Ousu
Username: Evadelparaiso
Puerto Rico
Post Number: 1049
Ousu do you run the last bin?
