i am just getting my box pieced together, but the sheet i got off of decaf site says the port is 3 inches wide. after putting the pieces together, the port is 6 inches wide at the front, and 3 inches wide after the port ''turns the corner''. does that sound right?
got another question. i got it all figured out, but at the end, the port was supposed to be 3 inches all the way through. mine ended up being 3.25 through the front, and then after it turned the corner, the other part was about 2.75 inches. will this still sound good?
no i got it all figured out. its done now. its about the same as yours, except its 39 wide, and 16 high. but right now it sounds really bad, cuz i havent sealed the hole where the wires go through. lol. and a lot of sh*it in my car rattles, and things are coming loose in different places.
go download AIM. if anything, the port is tuned to prolly around 32.2 - 33hz. somewhere in there. i got the measurements figured out, its only 1/8 inch off on part of it.
