New member Username: Escalade27New York USA Post Number: 1 Registered: Jun-06 | Hi Any Fix For Fortec Star Lifetime Classic Na? I Need Help Im Newbie |
New member Username: Mikeyboo41Post Number: 3 Registered: Jun-06 | i have the same fortec star u have..i need help with mine also. |
Bronze Member Username: CybercubiPost Number: 24 Registered: Mar-06 | Same here- no bin yet. I would check fortecupdate tho, that's the best one i think for the Classic NA. |
Bronze Member Username: Ssparkle0316Post Number: 12 Registered: May-06 | hey what software are u using i have something called dnupman is this the right software i need to download new bins |
New member Username: Sniper_1Marengo , Ohio Post Number: 1 Registered: Jun-06 | yes dunupmn is the only one that works with the classic na |
New member Username: Sniper_1Marengo , Ohio Post Number: 2 Registered: Jun-06 | yes dnupmn is the only one that works with the classic na |
New member Username: Sniper_1Marengo , Ohio Post Number: 4 Registered: Jun-06 | there is a new bin file for it. I dont think it is on here though |
Bronze Member Username: Willo1Post Number: 12 Registered: Jun-06 | is there any fix for fortec classic na. where can i find the files. please help soon. |
New member Username: Sniper_1Marengo , Ohio Post Number: 6 Registered: Jun-06 | I think i have it but I am not sure how to upload it. the site i got it from is down at the moment. |
Bronze Member Username: Willo1Post Number: 13 Registered: Jun-06 | t.chris post it when it's ready. thanks for help |
Bronze Member Username: Ssparkle0316Post Number: 13 Registered: May-06 | thanks chris, could u email the dnupman application, i think there may be a problem with the one i have my email is sparkleblue@bellsouth.net thanks |
Bronze Member Username: Willo1Post Number: 15 Registered: Jun-06 | sam if go to fortecstar.com u can download dnupman file under classic na. |
Bronze Member Username: MillaEdmonton, Alberta Canada Post Number: 41 Registered: May-06 | hey guys i have a fortec star life time but i dont know if its the classic. it doesnt say classic or ultra. now is there a fix for it? please help? |
Bronze Member Username: CybercubiPost Number: 25 Registered: Mar-06 | Abu- If you're not sure about your stb being the the classic then I would not load the classic fix on it... i dont think it will work and it may f#%@ up your receiver. T Chris - which site did you get the fix from? Is the 060607 or the new one? |
New member Username: ItguyPost Number: 2 Registered: Jun-06 | I have downloaded the LifeTimeClassicNA_375SUA_XPA_X_XL_060607.BIN file from dsstester*com. I still don't get the international and PPC channels. It keeps on saying that 'Please wait the code is being update....' and after few seconds it says 'Scrambled channel' I have tried deleting all the channels and re-scanning it. Did not make any difference. I am not sure if I am using the correct code. I downloaded the bin file upload-1149970089-X 85CS 060318 273T GC DN BEV RTN TV 4sec api N.bin file but my DnUpMan_EU_american_060330.exe s/w says invalide bin file. I have tried searching for more help on Classic NA but seems like not many people use this box. Any help is much appreciated. |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 826 Registered: May-06 | Do you need stop autoroll option, put the keys, and you go it. Remember set date and time zone. |
Bronze Member Username: SmalltigerPost Number: 17 Registered: Jun-06 | Sam Pat, use the 375sua bin then go into the code and you will see if the keys are there for dn.You may have to manualy insert the first two or the last two set of keys.The x85 bin is for ultra. |
New member Username: Kdjac0434Post Number: 1 Registered: Jun-06 | I am having the same problem. I have the LifeTimeClassicNA_375SUA_XPA_X_XL_060607.BIN loaded and I am receiving some channels, about 200 loaded when I scanned. Over half of them say scrambled channel when I try to watch them. I believe I have the right keys (they match what I see in the "new codes" post. What am I doing wrong? |
New member Username: RadibusaPost Number: 2 Registered: Jun-06 | i have a lifetime classic & i am a anewbie I have been tryin to change the date but it isnt moving the months...i just did a scan recently & the thing is stuck on channels being updated ..help |
New member Username: RadibusaPost Number: 3 Registered: Jun-06 | how do i change the box keys onn this thing |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 836 Registered: May-06 | kyle download the most recent fix in dss**tester.com |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 837 Registered: May-06 | radibusa: Go to dss**tester.com download the most recent bin. |
New member Username: PenuToronto, Ont Canada Post Number: 2 Registered: Jun-06 | plz hlpe for me fortec star lifetime classsic na plz some one halp me thx u |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 846 Registered: May-06 | what help do you need? |
Gold Member Username: LklivesPost Number: 3202 Registered: Jan-06 | here's the latest Lifetime Classic bin.. [link removed]#33108 I find the best site of info on this particular receiver is Remove the * from all links here..Must register first at both sites..FREE |
New member Username: SdishPost Number: 5 Registered: Jun-06 | Could someone clarify the following please:-- 1) Keys are normally posted in the following format Dish Network: N 0101 00: 98 F7 44 AC 5E 07 D9 ED 8A FF 3B 7E 65 71 F9 4E Needed for 61.5 and 121 N 0101 01: (active) 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC 2) Fortec Star Lifetime Classic NA receive has following format Provide Key 00 01 00: 98 F7 44 AC 5E 07 D9 ED 00 01 01: 8A FF 3B 7E 65 71 F9 4E 00 01 02: 71 9C 60 71 04 C1 39 AE 00 01 03: 88 FF F0 5E D2 4C F3 FC 3) I just want to know correct way/location of entering the keys. 4) Should I change "Provide ID" from 00 01 to 01 01? What about Key # 00, 01, 02, and 03? |
Bronze Member Username: KhurramppmcPost Number: 11 Registered: May-06 | Tanvir Don't change provide ID .Just enter the key in the following way 00 01 00: 98 F7 44 AC 5E 07 D9 ED 00 01 01: 8A FF 3B 7E 65 71 F9 4E 00 01 02: 71 9C 60 71 04 C1 39 AE 00 01 03: 88 FF F0 5E D2 4C F3 FC This is the correct format to enter the key on the Fortec classic NA dO YOU HAVE ALL THE INTERNATIONAL CHANNEL BACK India,Pak .If you have can you forward me the new file as i don't have the new file for that all i see on the website is for Fortec Ultra not Fortec Classic Please help Khurram |
Gold Member Username: LklivesPost Number: 3217 Registered: Jan-06 | I just posted the new Classic file link 3 posts above! |
Bronze Member Username: DghummanOntario Canada Post Number: 24 Registered: Feb-06 | can someone help me find the loader so i can upload the new file,which site can give me the loader for fortec classic, i went to fortecstar.com but i dont know which file to download and also where cani find the step step by instruction to download the file to the receiver |
New member Username: Kdjac0434Post Number: 2 Registered: Jun-06 | LK the file there is the one I have been using. EVA is the fix the new keys? I got the same results after I entered them. Most of the channels are still saying scrambled. |
New member Username: RadibusaPost Number: 4 Registered: Jun-06 | how do i get to chenge the box keys on my box manually |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 850 Registered: May-06 | no new Keys, the new bins are the new fix for scramble PPV, Premium, international etc channels. I not sure if dss***tester.com have the fix for ultra, go to dss***tester.com downloads area. |
Gold Member Username: LklivesPost Number: 3223 Registered: Jan-06 | The fix that I posted above for Classic works fine! |
New member Username: Kdjac0434Post Number: 3 Registered: Jun-06 | The Ultra file does not work on the Classic NA. when I select the file it says invalid firmware file. |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 851 Registered: May-06 | so sorry for misspelled go to this link for all Fortec bin fix ps remove *** |
Bronze Member Username: DghummanOntario Canada Post Number: 25 Registered: Feb-06 | eva can u tell me where to find the loader for fortec classic and step by instruction to download the latest file |
New member Username: Kdjac0434Post Number: 4 Registered: Jun-06 | LK some of the channels work with that file, but not all. |
Gold Member Username: LklivesPost Number: 3225 Registered: Jan-06 | Of course the Ultra file will NOT work on a Classic...each Fortec has their own files!...everyone knows that!...the ultra use the 277T bin...the classic uses the 375S bin |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 852 Registered: May-06 | Fortec Files » LifeTimeClassicNA_375SUA_XPA_X_XL_060607 Classic NA fix 07 Jun 2006 Date: 07/06/2006 - View Full Info - Downloads: 1450 - Download LifeTimeClassicNA_375SUA_XPA_X_XL_060607 (554.48KB) dss**tester.com downloads area |
New member Username: Kdjac0434Post Number: 5 Registered: Jun-06 | I have this file LifeTimeClassicNA_375SUA_XPA_X_XL_060607 Classic NA fix 07 Jun 2006 but most of the channels still say "scrambled channel" |
New member Username: RadibusaPost Number: 5 Registered: Jun-06 | my box has been on PLEASE WAIT CODE BEING UPDATED for 48 hours |
New member Username: PenuToronto, Ont Canada Post Number: 3 Registered: Jun-06 | Fortec Star Lifetime Classic Na plz help me if have some one instruction to download the latest file plz see thx u!!!!!!!!!!! |
New member Username: Mikeyboo41Post Number: 4 Registered: Jun-06 | cant load the file from my comp to the box..having trouble..any suggestions.. |
New member Username: ItguyPost Number: 5 Registered: Jun-06 | How do you disable Auto Roll? I have correct bin file downloaded as suggested above. My Classic NA keeps on saying 'please wait code being updated'. Someone mentioned earlier that disabling auto roll would help. |
New member Username: SmithmPost Number: 1 Registered: Jun-06 | Hi, I have FORTEC LIFETIME CLASSIC NA. I have downloaed this bin file "LifeClassicFTA_375SUA_XPA_NOX_XL_060206.bin" from FORTEC website and uploaded in the reciever. Now, I do not see any channel, even the CODE in the CHANNEL- MENU. Could any one tell me what I should do next? Smithm |
Bronze Member Username: CybercubiPost Number: 26 Registered: Mar-06 | Smith- Get the latest bin file at the site posted up in this thread, 060607 - that should solve your problem. |
New member Username: SdishPost Number: 6 Registered: Jun-06 | Khurram, Thanks for your guidance. I am still trying to get some solution, yesterday I tried "LifeTimeClassicNA_375SUA_XPA_X_XL_060607" but it did not work for me. I got same screen "Please wait, Chl being updated" |
Gold Member Username: LklivesPost Number: 3233 Registered: Jan-06 | All U people are amazing!...NONE of U bought a receiver and NEVER learned how to use it!...shame on U! why did U buy it , if U weren't going to learn about it...U all thought this was Plug N Play!...LMAO and before U all bought U should have realized that there is very little forums info available, because Fortec's have NOT been popular for years! |
Bronze Member Username: CybercubiPost Number: 27 Registered: Mar-06 | Mike- Make sure you have a null modem cable and not straight thru. Also, you need to use the dnupman loader, available at official fortecstar website. |
Bronze Member Username: Willo1Post Number: 16 Registered: Jun-06 | LK, for classic na this LifeTimeClassicNA_375SUA_XPA_X_XL_060607" file is not working for the indian channels. this is the one i have download on my receiver. if u can help please help me. what should i do? i have put the latest key manually, but still say's scamble channel and please wait, code being updated. thanks |
New member Username: Rufa33Post Number: 3 Registered: Jun-06 | Thank you LK for your inputs but the LifeTimeClassicNA_375SUA_XPA_X_XL_060607 file is not working, maybe one or two or ten people can't find out and not common to the plug & play you mention. But seems all of us who owns the Live Time Classic NA has same issue. We don't have all channels. The bin was the first to come but not fully working, if anybody got the time to make a fix, will be appreciated. |
New member Username: Kdjac0434Post Number: 6 Registered: Jun-06 | Danny that is the same situation I am having. Hopefully there will be a fix soon. |
New member Username: Mikeyboo41Post Number: 5 Registered: Jun-06 | any info yet |
Bronze Member Username: Steven_manPost Number: 20 Registered: Mar-06 | Hi I have down loaded this bin LifeTimeClassicNA_375SUA_XPA_X_XL_060607 but it says scramble Channel. I have this keys 00: 98 F7 44 AC 5E 07 D9 ED 8A FF 3B 7E 65 71 F9 4E 01: 71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC active This is what I have under my system Info. Mode: Lifetime Classic NA s/w 1.1 Jun 07 2006 h/w ver 2.0 szn4 Bootstrap v002 |
New member Username: ItguyPost Number: 10 Registered: Jun-06 | Same here. Unfortunately not. I have been searching for it since morning. The LifeTimeClassicNA_375SUA_XPA_X_XL_060607 was the first to come out but is not working for International channels and PPV. All the Classic NA users are reporting the same issue on this forum. THERE IS NO FIX FOR FORTEC LIFETIME CLASSIC NA YET!!! WE WILL HAVE TO WAIT AND SEE. |
Bronze Member Username: ItguyPost Number: 11 Registered: Jun-06 | Same here. I have been searching for a fix since morning. The LifeTimeClassicNA_375SUA_XPA_X_XL_060607 was the first to come out but is not working for International channels and PPV. All the Classic NA users are reporting the same issue on this forum. It is confirmed......THERE IS NO FIX FOR CLASSIC NA YET. WE WILL HAVE TO WAIT AND SEE. |
New member Username: CybergrekaPost Number: 2 Registered: Jun-06 | Hello.... I'm fairly new at this, I uploaded the X-85BL_060610_277T_au_api_ to my receiver and I can now view the PPV, but not the International channels, can someone help me out please? Thanks so much |
New member Username: Amna_imranPost Number: 2 Registered: Jun-06 | I just want to add one more voice to the rest of u. I'm also an unfortunate user of Classic NA. Every site I go to, the same problem is reported. The bin that everyone is mentioning is not good enough.Try to keep up this thread. Someone will help; I'm sure. |
Bronze Member Username: DghummanOntario Canada Post Number: 33 Registered: Feb-06 | when is the classic file going to come out this file is no good that many people have recomended a lot of people |
New member Username: PenuToronto, Ont Canada Post Number: 5 Registered: Jun-06 | Fortec Star Lifetime Classic Na plz help bec it not working plz some one help me thx u!!!!!!!!!! |
New member Username: Rufa33Post Number: 4 Registered: Jun-06 | Thank you guys for your input, we need to make it known and clear for people who doesn't own this particular Device that is NOT working. Some of the web sites have already removed the link to this file. So hopefully somebody will have the fix soon. Cross your fingers. Thanks for the help making the binary file. |
New member Username: WaterjugPost Number: 6 Registered: May-06 | well it is 7;17 central here and no fix yet for this fortec ultra lc na i tried some codes that boyace posted from the day before and they to didnt hit the opening to channels nice try though if there are any codes hope someone can post them but we will have to wait for a bit yet folks they seem to have hammered the new systems cause my bro. is using a nagra 2 card and he is up except for the ppvs so maybe we bought the wrong system to pirate tv bell especially.. so can i move my dish to get another sat. to come in free to air. |
Bronze Member Username: DghummanOntario Canada Post Number: 34 Registered: Feb-06 | i hope we get the file for fortec classic today the other file is no good. when there is a new file please let us know |
Gold Member Username: LklivesPost Number: 3288 Registered: Jan-06 | |
New member Username: EsieHARARE, ZIMBABWE ZIMBABWE Post Number: 1 Registered: Jun-06 | Ihave a Fortec Star Ultra Lifetime Receiver and I need the current codes for SABC. Please help me! |
Bronze Member Username: Willo1Post Number: 17 Registered: Jun-06 | this is best site to download fortec classic na files. |
New member Username: Rufa33Post Number: 6 Registered: Jun-06 | Go to this site they have a nice forum |
Bronze Member Username: MillaEdmonton, Alberta Canada Post Number: 44 Registered: May-06 | does anyone know what bin i can use for the fortec star life time. this is not the ultra. is there a fix for this one? |
Bronze Member Username: MinmikePost Number: 13 Registered: Apr-06 | need the same thing,fortec lifetime classic na! |
New member Username: MiauuCanada Post Number: 2 Registered: Jun-06 | Hola I am also waiting for the new fortec if anybody else finds it please we all waiting for thanx |
New member Username: BuggerPost Number: 4 Registered: Jun-06 | Neede help as most of us I've ULTRASTAR FTP5000. how to get it work? For inernational 121.Sitting with no reception for whole week. Are there any files to download? Tryed to rescan channels did't work , what else would help? |
Bronze Member Username: ItguyPost Number: 13 Registered: Jun-06 | FINALLY!!! FORTEC LIFETIME CLASSIC NA IS WORKING FINE. THANK YOU EVERYONE FOR ALL YOUR HELP. |
New member Username: FocousLivoina, Mi Macomb Post Number: 6 Registered: Jun-06 | classic na o6o613 bin out |
New member Username: FocousLivoina, Mi Macomb Post Number: 7 Registered: Jun-06 | classic na o6o613 bin out |
New member Username: FunalongthewayMississauga, Ontario Canada Post Number: 5 Registered: Jun-06 | I tried FTLNA using DnUpMan_NTSC_050408(2)but it says Receiver Not Detected? Does anybody have latest uploader or Bin file? Please help. |
New member Username: FunalongthewayMississauga, Ontario Canada Post Number: 6 Registered: Jun-06 | Anybody please help with FTLNA? Thanks. I need bin as well as uploader? |
Bronze Member Username: CybercubiPost Number: 44 Registered: Mar-06 | Bourne- The bin is out and posted, check the forum for threads with the Classic NA title. As far as the uploader, you are using the correct loader but sounds like your cable is the wrong one; you need to use a null modem cable not straight thru. |
