Username: Novice2006 Post Number: 14 Registered: May-06
Saturday, June 10, 2006 - 21:42 GMT I have two different set-ups recommended in a room that is about 17x11 and would appreciate any input: Option #1 Pioneer Elite VSX-74TXVI Def Tech Mythos One Floor Speakers Def Tech Mythos Three Center Channel Def Tech Multi-directional Surrounds Def Tech Supercube 2 Option #2: Denon 4306 Bay Audio Bebop (fronts) Bay Audio Jam Center Bay Audio Mini Cube Satellites Bay Audio Cube Subwoofer Samsung 56" S5687WX Mostly will be used for television and movies. About 5% or 10% music. Any opinions or different gear I should consider would be appreciated.
Username: Novice2006 Post Number: 15 Registered: May-06
Sunday, June 11, 2006 - 15:09 GMT I would really appreciate some thoughts.
Username: Floyd_1977 Plainfield,
IL
Post Number: 44 Registered: May-06
Sunday, June 11, 2006 - 20:40 GMT I would suggest first listening to any speakers you are considering buying. Auditioning speakers will be much more helpful to you than asking for subjective opinions from others who likely have different tastes. I'm just curious, but is there any reason why the Pioneer couldn't be used with the Bay Audio speakers or the Denon with the Def Techs?
Username: Mccambley BREEZY POINT,
NY
Post Number: 199 Registered: Jun-05
Monday, June 12, 2006 - 18:47 GMT I like Denon, the 4306 is loaded. I also like Paradigm speakers, but the Def Techs are also nice never heard of the Bay Audio's.
Username: Novice2006 Post Number: 16 Registered: May-06
Tuesday, June 13, 2006 - 00:39 GMT Thanks. Nathan, there is no reason why I cannot mix and match the receivers and speakers.
