Knight rider !
Username: Lance_barr
Post Number: 26
just loaded da new bin for pansat2500...
used 2300/2500 stb updater ..and 277 bin ..went all da way too 100% and waited for download complete to show up on my computer... now stuck on knight rider.. can anyone tell me what i did wrong ...and how to bring it bakk to normal ??
Username: Lklives
Post Number: 3294
<<< The dreaded "Night Rider" lights, or an "n" appearing on the front display
This is an easy one. Load up PFL (Pansat Factory Loader 2.1,0,0). Type "key:global" (no quotes) into STB Model.....U can use any pansat loader U want... Get Pansat factory bin 222 or 224 ready to download. Turn the receiver on and click download after you see the first green light, (if that doesn't work, start again clicking download at the 2nd green light, if that doesn't work, start again clicking download at the 3rd green light). This should crack the receiver and download would begin. (Also works for anyone trying to flash the stubborn 2700a receiver for the first time).
Username: Rocks
Post Number: 17
LK the Guru - Any help for me on CooCoo receiver.
Username: Lklives
Post Number: 3297
rocky racoon....I have never heard of or seen a coocoo receiver...NO sites carry files for it...U must return to the source and get files there..
Username: Rocks
Post Number: 19
Source is missing from his distination , he is LOST
Username: Lklives
Post Number: 3299
then U are LOST!...I cannot help U...
Username: Lada
Montreal, QC Canada
Post Number: 10
LK, help me please!
I hav a message:Can not open serial port!!!
Acces isdenied.
What I need?
Thanks.
Username: Lklives
Post Number: 3303
try another comport in the software loader settings...and U can go into computer...settings...control panel...LPT ports ..and correct that there too..
Username: Lada
Montreal, QC Canada
Post Number: 12
With Com 3 I have message: Write Faild (Er1)
I do not find LPT ports in Control Panel.
Help, me fix this problem please!
Username: Reyka
Arecibo, Puerto Rico Puerto Rico
Post Number: 18
LK..help me
when I give download him leaves a message to me that says
" flash update fails"
Username: Lklives
Post Number: 3308
bad /wrong cable or serial port
Username: Lada
Montreal, QC Canada
Post Number: 13
I have DB9 F/F Cable-6ft serie 6PD 9F/9F.
Username: Lklives
Post Number: 3311
what receiver?....diff receivers use diff cables..
Username: Reyka
Post Number: 19
I am using a serial cable, I am not using the null modem cable
Username: Lklives
Post Number: 3312
lada...i read elsewhere U have a Fortec Ultra...cable is good...comport is wrong!
Username: Lada
Montreal, QC Canada
Post Number: 15
LK, I tryid with Com 3, but I have message: Write Faild (Er1)
Username: Reyka
Post Number: 20
Lk, help me please.....
Username: Reyka
Post Number: 21
LK, if east use cable for pansat 2700a serves to me." Cables To Go 6-Ft. DB9 F/F Null Modem Cable"
for Radio shack
Username: Lklives
Post Number: 3317
2700 require a null modem cable...yes radio shack has them..
Username: Milla
Edmonton, Alberta Canada
Post Number: 43
LK do u know if there is a fix yet for the fortec star life time. this one isnt the ultra cab i still use the 277t bin on it?
Username: Reyka
Post Number: 22
thanks.. LK
Post Number: 27
also.. y would my box go knight rider ..wrong bin(277 on pansat2500) ? wrong loader ? someone get at me .. oh btw thank LK for da bin info
Username: Lklives
Post Number: 3323
incorrect uploading procedure, bad timing, wrong bin, wrong loader, using USB port are all causes of night rider lights..or a fussy receiver..
Username: Eng590
hey LK. i read and read almost all your posts. but there is a problem i am facing, i have a pansat2500a. i downloaded 277.bin. when i hook up the receiver to the tv. there is a "black out". seems like the receiver did not like the file. i then flashed it with the original bin, it worked fine. i got my channels back. but ofcourse, the bin is not right, so i flashed it agian with 277. and i am still facing the same "black out" problem. any help or suggestion LK?.. thanks. in advance.
Username: Banzai
Post Number: 28
Lada,
There should be a COM1 on your computer, except if your internal modem used COM1 already.
Right click on "My Computer" on your destop. When the "System Properties window" popup, select the hardware Tab -> device manager -> expand the "Port" which contains the COM & LPT.
As I mentioned above if the COM1 used by modem then you have to right click on COM3 and verify the property of that COM (verify the Device status if it's OK). If everything is OK you should able to Upload the BIN into your receiver either COM3 or COM1 (most of the case is COM1).
If there is NO COM1 on your PC (must be weird) then perform an ADD Hardware and select install from selected List (COM) and add the COM?? port on your PC whenever the system allows the COM. Sometime system reserves the COM1 or COM3 for modem (modem on my LT default to COM3).
BTW, most PC system has the LPT1. Check you PC hardware carefully so we can help further.
Username: Lada
Montreal, QC Canada
Post Number: 21
thien cang... thank you alot!
But I do not have in Device status COM3.Ther are
Port(COM & LPT):
Communications Port(COM1)
ECP Printer Port (LPT), and in Port Setting for LPT there are LPT1.LPT2,LPT3.
I do not understund what is that mean?
