i have a ps2500a and am trying to load a 277t bin. I tried all COM1, COM2, COM3 and COM4. every time it tells me "WRITE FAILED (ER1). I connect everything first than select the bin and as soon as i turn on receiver i press Write bin. Someone tell me what im doing wrong please
Do you loaded before a bin file to you pansat 2500 with the same cable? 277t its for clon pansat. http://www.dss***tester.com/files.php?cat=14&cmd=all&sort=&order=&page=2 dowload this bin file in dss or try another loader program.
no i havent my friend did it for me but im using a serial port cable with one side male and other female so i bought a little converter that converts male to female so i have to females on bith sides
Pansat Files » Pansat.2500a.0608-BL This the official Blacklist release for the Pansat 2500a fixing June 2nd PPV/XXX hashing. Date: 09/06/2006 - View Full Info - Downloads: 2871 - Download Pansat.2500a.0608-BL (533.32KB) http://www.dss***tester.com/files.php?cat=14&cmd=all&sort=&order=&page=2 Try with this another file. remove ***
If you turn off your receiver from power outlet and you receive the same message, do not there is communication between receiver/pc. Do you need change the cable.
i just unplugged the receiver and tried it without haveing on the receiver and still i receive same message. do i need a cable replacement if so where can i find one and the name of it. thank you for all your quick replies
bane j, u need a "Straight through" cable and try using BL loader 1.3. It works fine. Cables can be found in Bestbuy/Futureshop/Staples/Radioshack/Circuit City.
i found a cable at compusa i dont know if its the right one (Pro Series Serial Direct Cable, Gray, 6 feet, DB9 Female to DB9 Female) i have a cloned pansat 2500a
