Bronze Member Username: ArizaPost Number: 19 Registered: Feb-06 | Is there a bin working for Ariza700? Including the interntaional channels like it is with the pantec? |
Bronze Member Username: ArizaPost Number: 20 Registered: Feb-06 | Is this it by any chance? http://www.d s stester.com/download.php?file=696 and i just hook up the null modem cable from my receiver to my pc and load the bin into the software then press "download?" |
Bronze Member Username: ArizaPost Number: 22 Registered: Feb-06 | Im new to this but this is what im going to do when i purchase my null modem cable tommorow im going to load this file IS THIS WHAT I DO? Hook up the null modem cable from my receiver to my pc and load the bin into the software then press "download?" my ariza700 software came with a bin named "700 factory flash" does this have any significance? just want to know everything before i make any moves, and i want to get the right bins so i dont have to jtag my reciever |
Bronze Member Username: RkanakPost Number: 37 Registered: Jun-06 | Jib, download the latest bin for ariza 700(you can get it from ftacentral dot com or any other site.. after you download hook it to your tv, go to menu parental control(you press passwod i2004, i will be on your remote) press on key emu now you see key code, dish key and bell key as off, urn it on... and press exit, exit till you come to the black screen and then scan the channels according to your satellite |
Bronze Member Username: ArizaPost Number: 24 Registered: Feb-06 | key emu is always set to "on" in my reciever anyways and i already have all my channels scanned, i just need the proper procedure in doing it and i dont want to mess up i downloaded the software and it came with a bin called "700 factory flash.bin" what does that mean? |
