Hi. I have just a simple TV with cable. I have a VHS and a separate DVD. No DVD's work properly. They'll run a bit, and then start to crackle and thick white lines pop up during the crackle, then disappear. The movie color fades in&out and all have a 'redness' to them. I never had this happen before I bought the the DVD; however, I've tried another DVD and the same thing happens. It can't be every single movie, so it must be wrong wiring through the VHS. Can anyone help me fix this?
You can't connect a DVD through a VHS if that's what you're doing. Connect straight to the TV. If the TV doesn't have line inputs, you need an RF modulator.
