New member Username: Orange1234Post Number: 7 Registered: Jun-06 | Hey, i just flashed the clone 272v1 safe bin onto my reveiever.. everything worked great but when i connected the receiver back to the tv and everything.. i couldnt access parent control for some reason (i needed to acess parent control to access nagravision2 and to set default key).. so this is what i did, i wnet into antenna set up and loaded nimique 1.3... NOW i am able to access parent control but when i clicked on set default key there was no option for "EMU-ON" .. then i tried to endeter the new keys in nagravision 2 but why wont it store? everytime im done loading the keys i clik up on my remote to insert keys for 01, all my keys get messed up for 00 that i just entered... i was worried i was gonna mess up the flashing but its the opposite! lol please help anyone.. thanks in advance |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1073 Registered: May-06 | lol If you do not scan satellite and have channels you cant see parental control, because not there is channels to control! Scan satellite and you will have parental control. Lucky |
Silver Member Username: BoycePost Number: 278 Registered: Apr-06 | My friend, did you blind scan your channel yet?! If no channel, My parent can't kick my bu*tt for watch Po*rn. |
New member Username: Orange1234Post Number: 8 Registered: Jun-06 | ok, should i start from scratch adn reflash my receiver with teh same bin? |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1074 Registered: May-06 | NO only go to satellite select and scan |
New member Username: Orange1234Post Number: 9 Registered: Jun-06 | ok eva, im honestlly realyl sorry to keep asking you questions that to you are probable stupid questions but i have been trying on my own to get these channels and i think i may have messed it up more then ever.. i followed your instructions to load the bin and everything : Things you will need! 1.A computer with a com port! 2.The right cable to connect to your computer to your receiver! 3.GTROM LOADERv3.34 or newer!..or another loader like BL 1.4 4.New pansat 2700bin!..or another Pansat bin 5.LNB setup and the right switch! 6.Sat Signal at 70 percent or higher! -------------------------------------------------------------------------------- ----- 1.Power down receiver and computer! 2.Connect receiver to computer and power both of them up! 3.Start up gtrom loader v3.34 or newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished! 4.Turn off power to receiver and computer and remove the cable from the receiver! 5.Install cable from the lnb and the cable from the tv and the plug it up and power up the receiver! 6.Using your remote hit menu and the parent control then ok in second pin enter 0000 and then ok! 7.Then set default key..EMU-ON then ok! 8.Go to Nagavision2 then ok and check 00 and 01 keys. Put in new keys if need then hit ok to save! 9.Now installation then ok antenna setup then ok make sure you have 110 and 119 and check to make sure the switch is set right for both on the diseqc setting! If 110 is on 1 and 119 is on 2, set diseqc the same way! 10.Now go to blind scan and hit ok! 11.When finished exit menu and watch tv! To download the new bin go to dss**tester.com Pansat downloads area Download the 272v1 bin, go to search write Loader, download bl or gtrom loader, unzipped both files, and follow the instruction above. Lucky i got lost after step 5 because i couldnt get to parent contorl and now i scanned it like a million times and i didnt quite know what you means by "make sure you have 110 and 119" .. i really wish i could start from scratch.. is reflashing the same bin a bad thing? |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1076 Registered: May-06 | forget 5 step, go to menu, installation, antenna setup, select satellite, exit, go to installation, Satellite scan, select the satellite and ok to scan. You will see the channels, and then you will see parental control option. |
New member Username: Orange1234Post Number: 10 Registered: Jun-06 | ok, i already blind scanned earlier.. ill try what you just said |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1077 Registered: May-06 | When your receiver do not have parental control to select is because your receiver still do not scan any satellite channels, when you scan satellite channels you will see parental control option. I never called, or will call stupid question, its only a newbie question for answer. Lucky and let me know. |
Bronze Member Username: Orange1234Post Number: 11 Registered: Jun-06 | ok eva, did what u just said.. i have channle sbuit all have black screens but im assuming thats ebcause i have to enter the new keys. However, after i have entered keeys for 00 it doesnt store even though it flashes on the bottom right corner..the keys that i just enter in 00 immedialtey change after i try to switch back to "key number".. im nto sure hats going on, do you have any idea? oh and by the way tahnks eva for all the help you have provided me so far! |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1079 Registered: May-06 | ok know go to parental control second pin 0000 go to set default key twice and let me know. |
Bronze Member Username: Orange1234Post Number: 12 Registered: Jun-06 | wow eva, thanks os much it works now all channels including ppv and xxx.. althoguh the channels are not all alphabetically ordered..how would i make them in order again? thanks |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1081 Registered: May-06 | yes go to sat, select echostart package hit twice. |
Bronze Member Username: Orange1234Post Number: 13 Registered: Jun-06 | alright, thanks eva so much for your patience and your help. Because of you you saved my satellite. Thanks again and everythign you have done is much appreciated.. we need more of you! Thanks again |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1085 Registered: May-06 | Enjoy your receiver. The great guys are whos doing for us the bin and loaders. Im glad to help people. You welcome. |
New member Username: IjazsyedPost Number: 10 Registered: Apr-06 | hi I have pansat 3500s I am missing indian and pakistani chanels plese help me to get it back thankyou |
Gold Member Username: EvadelparaisoPuerto Rico Post Number: 1092 Registered: May-06 | are you missing channels today? |
Bronze Member Username: George12Garden grove, California Post Number: 13 Registered: Mar-06 | HI Eva , do you know whats the lates working bin for cools@t 4000pro? i got most of my channels scramble . thanks |
Silver Member Username: The_wank_artistPost Number: 947 Registered: Feb-06 | george, Bin file is called: Coolsat4000_norw_123_20060610_188.zip Can be d/loaded at: |
