Please Help!!!
Username: Amary
Hi! I just have a question that I hope someone can help me with. I have a WNC three head LNB with a direct dish. I have opened the heads and found out that there is one for 101, 110 & 119. Now im not sure how each signal is supposed to come. I have only been recieving one signal at a time. Is there something I am supposed to do to get all 3. I am fairly new at this kind of stuff. Any help would be appreciated.
Thank you in advance
Username: Lklives
Post Number: 3151
throw that dish away..its very complicated and U can only get the 91 and 110..unless u spend money and buy more LNB's..
its called a Phase 3 triple LNB DirectV dish..
for less tha $50 u can get a much better and easire dish to use..try ebay or buy/sell DSS furums like www.hashhu.c*om
Username: Azpride
LK
These keys for viewsat:
00 E8 70 B0 0A 8E 0A 3D C5
01 F3 59 C3 5F 1A DA 19 5C
88 71 9C 60 71 04 C1 39 AE < active
89 88 FF F0 5E D2 4C F3 FC < active
none of the PPV is working, LK do you have any working key for PPV??? it's working before with old key.
Username: Lklives
Post Number: 3154
Those are good keys!...but probably input incorrectly!
Username: Cosmic_ray
Toronto, Ontario CANADA
Post Number: 40
For BIN PANSAT 2700A
http://www.pansatusa.com/download.htm
Username: Lklives
Post Number: 3155
Viewsat lines 08 and 09 hold Idea key 1 and 88 and 89 hold Idea key 0...all 4 lines must have the correct keys to receive all the channels..
A N2 key now is 32 bytes divided into two string lines of 16 bytes each. The idea key 0 goes into lines 08 and 09 in the code option and idea key 1 goes into lines 88 and 89 in the code option. As with N1 encryption, usually one idea key is active and the other is not. If you know the active key but unsure if it is the 0 key or 1 key, you can enter the key twice, repeating the 08 and 09 entries in 88 and 89 lines. This is not recommended as we see dish will run two active keys at one time.
thill1951
Username: Thill1951akalk
Post Number: 1177
Posted on Saturday, December 24, 2005 - 01:03 pm:
You can do it two ways:
1. load the latest opkey file... see posts below for the currently active on dated Dec 3 7 pm
2. use your REMOTE control... here's a "ficticious" example when you have the KEYs to use your REMOTE:
PRETEND Public Key Change by teach (12-04-05)
The Public Keys are reported to have changed to:
Key 00: F2 98 74 44 1C 65 77 D8
Key 01: 17 E3 E1 1D 89 4E 53 45
Here's how to change them in your ViewSat:
MENU--INSTALLATION--CODE--NAGRA
LEFT arrow until "Dish" displays in the top line
DOWN arrow x 2
RIGHT arrow x 1 puts you on the 2nd line of numbers with "08" in the first column;
you start punching in the below at the 2nd column ("C3" as of 11-04-05)
"Text" key + "2" = "F2", RIGHT arrow
"9" + "8" = "98", RIGHT arrow
"7" + "4" = "74", RIGHT arrow
"4" + "4" = "44", RIGHT arrow
"1" + "F3" key = "1C", RIGHT arrow
"6" + "5" = "65", RIGHT arrow
"7" + "7" = "77", RIGHT arrow
"F4" key + "8" = "D8", RIGHT arrow ...
finishing the top line
You should have the highlighted box in the first column of the 2nd row on top of "08"
DOWN arrow, RIGHT arrow to the 2nd box in the 3rd row
"1" + "7" = "17, RIGHT arrow
"LAST CHANNEL" key (below "9" key) + "3" = "E3", RIGHT arrow
"LAST CHANNEL" key (below "9" key) + "1" = "E1", RIGHT arrow
"1" + "F4" key = "1D", RIGHT arrow
"8" + "9" = "89", RIGHT arrow
"4" + "LAST CHANNEL" key = "4E", RIGHT arrow
"5" + "3" = "53", RIGHT arrow
"4" + "5" = "45", RIGHT arrow
EXIT, "YES" to save
EXIT to TV screen and watch tv
This puts the PRETEND KEYS into the 08 & 09 KEY lines.
If you need to put KEYS into the 88 & 89 KEY lines... do above and substitute 88 for the "08" line and 89 for the "09" line.
thill1951
Post Number: 1178
Posted on Saturday, December 24, 2005 - 01:05 pm:
here's what Posted keys looks like...VERY IMPORTANT INFO at bottom of post here..
BELL EXPRESSVU
12/23/05
Idea key 0:
20 2E EF 78 DA F6 38 3D
0D E5 30 FC FC B6 2B 68 ...Key is Active
Idea Key 1
BA 3A 15 E5 32 AC 6B FC
2C 93 E0 3C 80 A2 7F 24
DISH NETWORK
12-23-05
Idea Key 0:
AF 0C BD 48 D8 51 6D DC
FE 44 D6 0C A3 6E 59 42 ...Key 0 has become active 12/20/05
Idea Key 1:
FB D9 F2 D9 D6 C9 EF 7A
57 AD 32 24 67 42 6C E6
Globecast
00 0C A6 6D FF EF E9 4E C8
01 2A 93 49 EA A7 B9 15 EE ...N1 Keys????
VERY IMPORTANT BELOW!!!!!!
C*oolsat Slot 10 and 11 are for Idea Key 0 and Slot 20 and 21 are for Idea Key 1
Pansat key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
For Receivers with only two Key Slots, Enter Active Idea Key into 00 and 01
Username: Ellocoloco
I have a 2700 can some one tell me where I can buy the correct cable to download the update from my laptop to the pansat 2700. My computer has nowhere to connet the RS 232 cable.
thanks for your help.
Username: Azpride
LK: i entered the key as instructed;
00 key did not change, but 01 keys is changed
why PPV doesn't work, is your working ok?
00:
01:
71 9C 60 71 04 C1 39 AE (new)
88 FF F0 5E D2 4C F3 FC (new)
