LK World Cup on 121?
Username: Main420
Post Number: 46
Hi,
Can I get a channel for world cup on satellite 121? If not, what other satellite should I get to get world cup?
Thx man
Username: Mestre1966
Post Number: 22
ESPN2
Univision
ABC
just go here...
http://www.soccertv.com/
Username: Costeno_mex
Winston salem, Nc Usa
HOLA
EVA ME PUEDES AYUDAR
TENGO UN PROBLEMA CON MI PANSAT 2500A
CUANDO CARGO EL BIN 277
LO QUE OCURRE QUE EN MI COMPUTADORA CARGA EL 100%
PERO EN EL RECEIVER SOLO LLEGA HASTA EL 83%
Y EL RECEIVER SE QUEDA CON UNAS LINEA EN EL DISPLAY Y NO SE PUEDE APAGAR NI ENCENDER
ESTO ES NORMAL.PUES CON LOS BIN ANTERIORES
NO TENGO ESE PROBLEMA
AHORA TENGO EL BIN 273 Y SOLO PUEDO VER ALGUNOS
CANALES ME PUEDES AYUDAR POR FAVOR
GRACIAS
Username: Cybercubi
Post Number: 22
Shane-
Channels 400-410 on Nimiq 1 also will show the games, or, setanta onT5 (IA5) if u have linear polarity LNB.
Username: Milla
Edmonton, Alberta Canada
Post Number: 42
LK i fixed my fortec life time ultra thanx.
no i need to fix my friends fortec star life time.is it the same fix as the ultra?
please and thanx
Username: Main420
Post Number: 49
thx
Username: Evadelparaiso
Puerto Rico
Post Number: 816
hector:Flash Failed..Night rider fix, .. and Loading bins..
Flash failed is either a defective cable or SERIAL port; or use of the wrong cable or comport..
Here is how to recover from the "Night Rider" (flashing lights):
1. Try re-flashing the factory boot/flash again using the below directions. That gives you FTA ONLY. Follow the above procedure.
2. Then, when that works use the latest flash to get the scrambled channels.
3. Download a channel list and/or do a channel scan on each sat.
4. When flashing, be sure to wait not only until is says done. But you need to wait until it reboots and actually goes to a channel number.
Here are a few tips if you are having difficulty flashing: loading a bin..
I would advise everyone to read a set up guide before flashing. But, since people have been having some problems, I have revised this to provide more detailed information. But this is not intended to be a substitute.
1. Make sure you use the proper serial cable for your receiver:
Most Fortec and Pansat use a straight through cable with DB9 females on both ends.
The Blackbird, Pansat 2700/3500 and some other receivers use null (crossover) cable, which crosses over pins 2 and 3.
2, With the power turned off, connect it to your computer and receiver using the serial connector. Use serial port #1 if you can.
3. If you do not have a working SERIAL port, you must install one or use a computer that has one. Usb ports do NOT usually work, except on rare ocassions with an adapter.
4. Use the appropriate loader.
5. Select the file. Make sure that it is the correct flash for your receiver.
6. Select the COM port your receiver is connected to. If you do not know, what it is try #1 first.
7. Enter the correct model name and number. Most Blackist updaters do Not require this.
8. Check off the correct function box. Your choices are boot, flash or channel list. To FLASH your receiver you would use FLASH. Most flashes do not require a separate boot; so do not load both separately.
9. Turn on the receiver power from the BACK switch.
10. As soon as you see the lights flash,very first light -- IMMEDIATELY press download. Timing is critical and many vary.
11. Wait until it COMPLETES and reboots.
_________________
Pansat setup guide..
[link removed]
Dishnet keys..
[link removed]&start=240
Keymaster 2.0..
http://dsscommunity.c*om/forums/viewtopic.php?t
