New member Username: Dnnnn
Post Number: 1 Registered: Jun-06
Posted on ok i read all ur tips and convesation but i still have two questions: !) I have a pantec. how can i know if it has been cloned to pansat? 2) If my receiver is colned to pansat 2500a should i use pansat2500a bin and loader or the pantec bin and loader? Thx for ur time and answer. |
Bronze Member Username: Tadon
Dover,
NJ
Usa
Post Number: 18 Registered: May-06
Posted on No . I remembered LK/Tylr/Eva said :-)) it will kill your system . Ask for clone BIN. |
Silver Member Username: Evadelparaiso
Puerto Rico
Post Number: 813 Registered: May-06
Posted on mal: The name pantec=pansat clon if you have pantec yes its a clon. Do you need use a bin for clon if you use another bin do you will need jtag. |
