Subwoofer cable
Username: Ibobb7
Do I NEED a special subwoofer cable? I have just a normal bookshelf stereo system (not some super surround sound deal) and I want to know how much quality I would give up using plain old component cable.
Username: Floyd_1977
Plainfield, IL USA
Post Number: 10
No, there's nothing special about a "subwoofer cable". If you have a spare RCA cable, why not just try it out?
Username: Alvizgransee
Can a (active) subwoofer cable be cut/modified to connect to a passive 2-wire (subwoofer) connection ?
Frank
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1599
Your thread has the same title as one 4 titles down the list. Have you read it?
https://www.ecoustics.com/electronics/forum/home-audio/226885.html
