Bronze Member Username: BladamPost Number: 31 Registered: Apr-06 | how would I go about downloading bin fortec, using 277 bin for pansat please guide me |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 769 Registered: May-06 | https://www.ecoustics.com/electronics/forum/home-video/234603.html REad all please do not run the bin for clone |
Bronze Member Username: Hawks134Post Number: 22 Registered: Jan-06 | When I donwload the bin its say failure and retry. My Pansat 2500A has a couple of lines across it and shuts off and comes back on. any help? |
Bronze Member Username: Hawaiian_timePost Number: 37 Registered: Apr-06 | Ted, did you flash your receiver with the factory bin before loading the new one? |
Bronze Member Username: Hawks134Post Number: 23 Registered: Jan-06 | no how do you do that? |
Gold Member Username: LklivesPost Number: 3153 Registered: Jan-06 | U HAVE NITE RIDER LIGHTS FROM INCORRECT LOADING PROCEDURES..NEED TO READ HOW TO LOAD A BIN CORRECTLY...THEN UPLOAD THE FACTORY 222 OR 224 BIN , THEN THE 277 BIN.. U were impatient and thought this was Plug N Play...now U figure out the rest yourself! |
Bronze Member Username: Hawks134Post Number: 24 Registered: Jan-06 | I tried to flah the factory bin and it came up...model not correct? |
Gold Member Username: LklivesPost Number: 3165 Registered: Jan-06 | model.... key:global or use BL V 1.4 updater to uplaod the bins.. |
Bronze Member Username: Hawks134Post Number: 25 Registered: Jan-06 | Where can I get the bl v 1.4 loader at? |
Gold Member Username: LklivesPost Number: 3179 Registered: Jan-06 | dsscommunity or any dss site |
Bronze Member Username: RohitkamahiPost Number: 15 Registered: May-06 | Here's the link for the Black List Updater 1.4. Before you download, you have to register and it's free. replace * with a dot |
