I don't know what you mean 25pin, if yours pc has 25 pin com port = yes, if printer port= no, if com port you can use the adeptor from DB25 to DB15 , and plug the cable ( null moden / straight, base on what recevier you have.)
I have a RS 232 cable, one end is a female 9 pin connector(which goes to reciever), the other end is a 25 pin male connector(which goes to PC). Is this usable to download bin? Thank You!
My PC has a 25 pin com 3 port. My cables are 9 pin to reciever, and 25 pin to PC connectors. They are RS 232C cables. Is this usable to perform the download? I have the bin file, and the loader, I just need to know if I have the correct cable connection. Thank You!
