Help:Trying to load bin123 in cols t 4000 (Wont Load)
Username: Waydown
I am using pro loader 2.4 ,on com 1,I keep geting a pop up telling me to connect and turn on my reciver.
Username: Miguel03
Tucson
Post Number: 12
turn on the sitch on the back of the box, and the one on the front of the box. Press auto detect and that you should detect your current bin.
Username: Waydown
im using a 9 pin db9 null cable ,i must need the one that switshes pin 2 and 3,want connect ,seems like com 1 not working,but com 1 is working.
Username: Qbee
Post Number: 26
stupid question - did you turn off the box before connecting?
did you try auto detect and do it again after wiggling your connections?
Sounds stupid ... but it finally worked for me.
Username: Waydown
Qbee, I have tried every thing but a new 9 pin cable ,dont have one today,
