Need Help - Fortec Star Lifetime Ultra receiver damage
Username: Infinite
Post Number: 11
I just loaded 277 bin in my fortec star lifetime ultra receiver. I was able to load the file successfully, but could not get even menu. So seems like this file is not clone safe.
Any suggestions on how fix or how to roll back to previous state? Do I just load 273 bin?
Thanks
Username: Evadelparaiso
Puerto Rico
Post Number: 757
Infinity check in your email.
Username: Infinite
Post Number: 12
Eva, I would really appreciate if you can get me out of this problem. As always, you are always ready to help anybody.
Puerto Rico
Post Number: 760
Infinity emailme with your email address.
Username: Infinite
Post Number: 13
Eva, I have send my email message. My earlier email was bouncing hence I updated with the new one. So if you resend me the information, I should be able to receive it now.
Thanks for all the help.
Username: Infinite
Post Number: 14
Eva, can you resend me the instructions as I changed the email address? I have also mail you my email address as well.
Thanks.
Username: Nascar
A new fix for ultra should be out as of later this afternoon, from what i have been told the new fix works but may be dangerous for ultras until it is not moddified, mods are in the process as we speak. 1 MORE FOR THE GOOD GUYS!
Username: Infinite
Post Number: 15
Eva, would you be able to help me with my fortec star lifetime ultra receiver that I damaged because of loading 277 bin file.
Thanks.
