Go to the thread and follow the instructions step-by-step. The correct Keys are already in the bin. You do not need to put them. Do not forget to "set default key" otherwise you will get "scrambled channel" message.
You have to be a member of f o r u m s . a l 7 b a r . t k then go to : f o r u m s . a l 7 b a r . t k / s h o w t h r e a d . p h p ? t = 1 6 0 6 3 1
