Linear LNB Ku
Username: Karla
Post Number: 32
Does anybody has a picture of a linear LNB Ku and its features??
thank you
Username: Zagros
Post Number: 22
http://en.wikipedia.org/wiki/Low-noise_block_converter
Username: Zagros
Post Number: 23
http://www.prosatellitesupply.com/BIG_DISH_ACCESSORIES_and_REPLACEMENT_PARTS.htm
Username: Evadelparaiso
Puerto Rico
Post Number: 735
I love wikipedia
Username: Soheilsexy
Post Number: 14
[link removed] pansat 2700 new availble now...
Post Number: 15
ok send me pansat 2500A bin 2700 i posted
Username: Karla
Post Number: 33
Username: The_wank_artist
Post Number: 815
LINEAR-POLARIZED DUAL-FEED Ku Band LNBF $39.99
This Dual-Feed (Linear-Polarized) Ku Band LNBF will support one or two free-to-air satellite receivers in the Ku Band Frequency Range. RF Range: 11.70 to 12.20 GHz. IF: 950 to 1450 MHz. LO: 10.750 GHz. Gain: 55 dB. Noise Figure: 0.5 dB. Designed to work with any 18-inch, 24-inch or 30-inch dish AND with any mount: Rectangular-Tube, Square-Tube, D-Tube, or Universal Mounting Bracket. However, most linear-polarized Ku satellite feeds require skewing for maximum signal interception - therefore, we recommend this LNBF be used in conjunction with a Dish Equipped with a Universal Mounting Bracket. .Upload
Username: Lklives
Post Number: 3134
do not hijack threads!
Username: Karla
Post Number: 34
Thank you Tyler,
I think that's the LNB (with a 33inch dish) that I need so I can get a satellite (Amazonas) that is 61degrees west
Post Number: 826
Cool.
I got the info from Zagros' posted link...
Username: Karla
Post Number: 35
Thanks again...wish me luck
Username: Lklives
Post Number: 3140
for Dishnet 61.5 west...all U need is a regular 18-20 inch dish and a regular circular LNB..
