What speakers do you hook up to the back of the powered subwoofer? Cause I have no idea, im guessing it the fronts, but im not sure so if antone could clear this stupid problem up for me that will be great. Thanks
Derek
If the subwoofer has speaker level in AND out AND has a cross-over for the sub AND the speakers - the fronts.
If your receiver has a subwoofer pre-amp output AND the subwoofer has a line level input - just connect all of your speakers to the receiver the way you normally would and run a line to the sub from the receiver. Try setting all speakers to large and see how it sound, then try setting them to small and pick the one you prefer.
