Hey can someone please help me with the wiring codes for a 94' intrepid. Also I see here that you keep putting "constant 12V" and "switched 12V". Which wire from my Pioneer CD Player would I hook up to the the "constant 12V", "ACC (Red)" or "battery (Yellow)". I am also left with one wire left over... Sorry if those are stupid questions. My dash lights and tail lights are no longer working once I hooked up the CD player that is why I need help, which wire would control these, or could I have blown a fuse.
Does anyone know the wiring schematic for a 1994 Honda Accord EX Sedan and a 1999 Honda CRV? Also, would I be able to buy harness adapters that plug into the OEM harness and have bare wires on the other end at a place like Auto Barn or Pep Boys? I want to keep my OEM harnesses intact, but I also need the raw end adapters by saturday and cannot wait 5+ business days for ebay sellers. Thanks!
Eric, u can get an aftermarket harness from pepboys and stores like that,BUT i don't no if they have the OEM...
Accord
A Right Rear Spkr (+) Red w/ Yellow Stripe Left Rear Spkr (+) Blue w/ Yellow Stripe Power Antenna Trigger Brown w/ White Stripe Blue +12 Volt Ignition Wire Yellow w/ Red Stripe Right Rear Spkr (-) Brown w/ White Stripe Left Rear Spkr (-) Gray w/ White Stripe Ground Wire Black +12 Volt Battery Wire White w/ Yellow Left Front Spkr (+) Blue w/ Green Stripe Right Front Spkr (+) Red w/ Green Stripe Left Front Spkr (-) Gray w/ Black Stripe Right Front Spkr (-) Brown w/ Black Stripe
CRV::
Constant 12V+ White/Blue Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer Red Front Speakers Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Doug you would hook up the constant to the YELLOW wire,and switched to the RED
Right Rear Spkr (-) Blue w/ White Stripe Left Rear Spkr (-) Brown w/ Yellow Stripe Right Front Spkr (+) Purple Left Front Spkr (+) Dark Green Right Rear Spkr (+) Blue w/ Orange Stripe Left Rear Spkr (+) Brown w/ Blue Stripe Power Antenna/Amp White (use for Infinity Radio) +12 Volt Battery Wire Pink or Pink w/ White Stripe +12 Volt Ignition Wire Red w/ White Strip Right Front Spkr (-) Blue w/ Red Stripe Left Front Spkr (-) Brown w/ Red Stripe Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire Black
Thanks a lot, but I also have an orange wire coming from the car, that I have no use for. Should I just tie it off? I connected the braid to the back of my CD player but the car also has a black/gold stripe cord (I believe.)should I attach that to the black ground wire from my CD Player? You've been a huge help, thanks.
Just replacing the factory deck on my 99 C280 Benz, I noticed you had a post of the '90 E series and I was wondering if that diagram also applies to my deck? Thanks!
Thanks for the wiring info. The harness I need is an aftermarket harness. I just need one that plugs into the original one and has bare wires on the other end so that I wont have to splice the wires on the original harness.
1999 Mercedes C-Class Constant 12V+ Pink/Green Switched 12V+ Red/Blue Ground Brown Illumination n/a Dimmer Gray/Blue Antenna Trigger Blue/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Green Left Front (-) Brown/Green Right Front (+) Orange Right Front (-) Brown/Orange Rear Speakers 6 1/2" Rear Deck Left Rear (+) Pink Left Rear (-) Brown/Pink Right Rear (+) White Right Rear (-) Brown/White
how about a 1997 hodna accord lx? I need to doublecheck the installation, some of the connections are definitely wrong. I'm sorry if it was already on the page and I'm just oblivious. Thanks.
1997 Honda Accord Stereo Information Constant 12V+ Yellow/White Switched 12V+ White/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
from the cd player? i have everything disconnected no fuses are blown to my knowledge is there any specific duse under the hood that could cause them not to work? i looked in the manual and it doesnt show any just fuses to the head lights its for a 99 isuzu rodeo
1997 Volkswagen Jetta Stereo Information Constant 12V+ Red/White Switched 12V+ Gray/Blue Ground Brown Illumination n/a Dimmer n/a Antenna Left Front Front Speakers 6 1/2" Doors Left Front (+) Blue/Black Left Front (-) Orange/Blue Right Front (+) Red/White Right Front (-) Orange/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red/Light Green Left Rear (-) Orange/Black Right Rear (+) Blue/Light Green Right Rear (-) Orange/Red
1998 Dodge Stratus Stereo Information Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground n/a Illumination Orange/Brown Dimmer Black/Light Blue Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
1996 Ford F Series Stereo Information Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Side Panels Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
1995 Ford F Series Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red or Black Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 6" x 8" Side Panels Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
1998 Ford Escort Stereo Information Constant 12V+ Blue/Red Switched 12V+ Blue/Black Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger n/a Antenna Driver's Pillar Front Speakers 5 1/4" Doors Left Front (+) Purple Left Front (-) Blue/Orange Right Front (+) Blue/White Right Front (-) White Rear Speakers 6" x 8" Rear Deck Left Rear (+) White/Blue Left Rear (-) Red/Blue Right Rear (+) White/Green Right Rear (-) Blue
Alarm Information Cruise Information
1998 Ford Escort ZX2 Stereo Information Constant 12V+ Blue/Red Switched 12V+ Blue/Black Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger n/a Antenna Right Rear Front Speakers 5 1/4" Doors Left Front (+) Purple Left Front (-) Blue/Orange Right Front (+) Blue/White Right Front (-) White Rear Speakers 6" x 8" Rear Deck Left Rear (+) White/Blue Left Rear (-) Red/Blue Right Rear (+) White/Green Right Rear (-) Blue
1994 Nissan Maxima Stereo Information Constant 12V+ Red/Black Switched 12V+ Blue Ground n/a Illumination Red/Yellow Dimmer n/a Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
1989-90 Nissan 240 SX Stereo Information Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Red/Blue Dimmer Red/Yellow Antenna Trigger Black/Red Antenna Left Rear Front Speakers 4" x 6" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
i need help!!! i have a 1999 isuzu rodeo and the factory wiring end has been cut off i then wired it directly to the cd player as a result. i have lost dash lights since then. the fuses are all fine and no wires are touching each other how would i check the fuses with the test light and there isnt any fuse under the hood that is labeleed for interior lights. is there a inline fuse that rodeo would have put in and if so would you know where?
need some help,I installed a new stereo in a 90 Escort and it wouldnt work so I switched back to the factory stereo and now it doesnt work either,the fuse is good,,,any suggestions?
Got my hubby a CD player for his 2003 F-150 supercab. Thought I did so well, getting dash kit and harness... BUT... found out when he gets the dash all torn apart, that the guy at the store sold me the wrong harness (Scosche FD23B).
So I call Scosche, they tell me to get FDK106. Still not right. One of the plugs fits, but theres a square plug with 20 pins - lined up in rows - 7/6/7 that doesn't match up to anything.
What are we missing? What does this plug's wires hook to? I'm stumped and can't even find wiring info anywhere.
i have a 1992 supra with the optional 10 speaker sound system and amp, im upgrading the original head unit to a cd player, there is no apdapter for it and i just cant make head nor tail of the wiring system, the original head unit is a fugitsu ten - 86120 - 2b320, please help.
Hey whats goin on, I need some help, im tryin to put a new radio in my 91 ford aerostar, its a Kenwood KRC-207s, and i can not figure out how to splice the wires, can anyone help me? Or can it even be done? I would appreciate any help. thnx
1991-92 Ford Ranger Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Chassis Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Rear Wall Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
1991 Ford Aerostar Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red or Black Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" Dash Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 3 1/2" Tail Gate Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
1991 Toyota Cressida Stereo Information Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Rear Front Speakers 5 1/4" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 6 1/2" Rear Deck Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
1991-93 Ford Escort Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Driver's Pillar Front Speakers 5 3/4" Doors Left Front (+) Orange/Green Left Front (-) Blue/Light Green Right Front (+) White/Green Right Front (-) Green/Yellow Rear Speakers 4" Side Shelves Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
1998 Nissan Altima Stereo Information Constant 12V+ Pink Switched 12V+ Blue Ground Vehicle Chassis Illumination Red/Green Dimmer Red/Yellow Antenna Trigger Green/White Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Brown Left Front (-) Black/Red Right Front (+) Light Green Right Front (-) Black/Yellow Rear Speakers 6 1/2" Rear Deck Left Rear (+) Orange Left Rear (-) Black/Pink Right Rear (+) Blue Right Rear (-) Black/White
i have a 1999 isuzu rodeo and the factory wiring end has been cut off i then wired it directly to the cd player as a result. i have lost dash lights since then. the fuses are all fine and no wires are touching each other . how would i check the fuses with the test light and there isnt any fuse under the hood that is labeled for interior lights. is there a inline fuse that rodeo would have put in and if so would you know where? Also this may halp when i turn the switch to tun on my dash lights the gear lights dim from a bright green to a very light barley visible green. The gear lights are the only ones on the dash that do work.
go to each fuse, on each fuse there are 2 sides(2 metal pieces on top) to it, test both sides of fuse, it may be blown in the middle, allowing current in but not out.
1990-91 Ford Explorer Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Black Illumination Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Green Left Front (-) Blue/White Right Front (+) White/Green Right Front (-) Green/Orange Rear Speakers 5" x 7" Rear Doors Left Rear (+) Pink/Green Left Rear (-) Brown/Yellow Right Rear (+) Orange/Red Right Rear (-) Black/White
i just bought a 1991 Toyota Celica GTS and the guy who had it mutilated the stereo harness. i need the color codes to re-wire it. if someone can get these it would be great.
1990-93 Toyota Celica Stereo Information Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Left Rear Front Speakers 4" Dash Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5 1/4" Side Panels Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
I have recently purchased a new head unit for my 2001 Pontiac Sunfire. And am now having trouble with the installation as far as wiring goes. I am unable to find the switched 12V+ wire. If someone could please list a wiring guide for my stereo it would be much appreciated. Thank you.
looking to ger a wireing breakdown on a 85 LTD Crown Vic it is an odd 5 wire system like I have never seen before would love any ssistance i could get thanks Chris
ok I got most of it figured out I think. Would still love a color spec, but a new problem arose. I got it wired together and now my speakers will not work with either the original stereo or the new stereo. Any tricks to figure it out would be greatly appreciated.
i have a 1995 ford f-150 with original equipment stereo with cassette and am installing a sony stereo. does anyone know the wiring systems from the ford? the ones above dont match up
buy the aftermarket harness for it, here is the colors
I'm just replacing the head unit on a Ford Explorer 2002 XLT - I have the Haynes wiring diagram for the radio. But I don't know where to wire the existing "vehicle speed" & "air bag contact" wires that were connected to the original Ford Unit.
quibs, what are yu replacing it with, if aftermarket, buy the aftermarket harness that adapts your factory harness and then attaches to the radio harness.
1999 Acura Integra Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger n/a Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
1990-91 Ford Crown Victoria Stereo Information Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Chassis Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
1980 Olds Cutlass Supreme - need wiring info, online wire to wire I found isn't right. have pink, gray, yellow, gray wires (non speaker)from dash and blue w/brown stripe, orange w/blue stripe (says IILUM), red w/blue stripe and yellow from deck plug. Also have gray with a big blob on the end from car. Hooking up Alpine CDE 9843
1990 Toyota Cressida Stereo Information Constant 12V+ Blue/Yellow Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Rear Front Speakers 5 1/4" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 6 1/2" Rear Deck Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
1994 Dodge Shadow Stereo Information Constant 12V+ Red Switched 12V+ Red/White Ground Chassis Illumination n/a Dimmer Orange/White Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 5" x 7" Side Shelves Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
1997 Jeep Wrangler Stereo Information Constant 12V+ Pink/White Switched 12V+ Pink Ground Vehicle Chassis Illumination Orange Dimmer Black/Yellow Antenna Right Front Front Speakers 4" x 6" Dash Left Front (+) Brown/Red Left Front (-) Green Right Front (+) Blue Right Front (-) Purple Rear Speakers 5 1/4" Roll Bar Left Rear (+) Brown/Yellow Left Rear (-) Brown/Blue Right Rear (+) Blue/White Right Rear (-) Blue/Red
2000 Pontiac Sunfire Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Do n e 1 know the right wiring for a '99 special edition ford contour so i can get this stinkin radio in that raggedy car cuz it's driving me insane!?! my wire harness was cut out and the wires r different from whats been given to me... i got the colors listed on the forum...would somebody please help a fellow driver regain some music for the road
I have a 2002 Saturn SL1, I'm trying to install a Dual XM stereo, but there are some wires coming from my saturn that i dont recognize. can you help me ty
i have a 1993 ATURN I NEED HELD WITH THE WIRES I AM TRYING TO HOOK UP A SONY CDXC620,AND A SANY AMPA 1502 SX . WHAT WIRES DO I HOOK THE TRADIO UP TO AND WHRE WOULD BE A GOOD PLACE TO GROUND THE AMP IT KEEPS ON SHUTTING OFF. AND THE LIGHT DISPLAYS "OFFSET" WHAT F------ GIVES. PLEASE HELP
| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V |red |+ | ignition harness | | STARTER|yellow |+ |ignition harness | | IGNITION|pink |+ |ignition harness | | SECOND IGNITION|green |+ |ignition harness | | THIRD IGNITION|lt grn (key sense)*7|- |ignition harness | | ACCESSORY|orange |+ |ignition harness | | SECOND ACCESSORY|brown |+ |ignition harness | | POWER LOCK|orange/black |+ |drivers kick panel | | POWER UNLOCK|red/black |+ |drivers kick panel | | LOCK MOTOR|gray | |drivers kick panel | | UNLOCK MOTOR|tan | |drivers kick panel | | DISARM DEFEAT|tan | |passengers kick panel | | PARKING LIGHTS +|brown | |steering column | | HEADLIGHTS|blue *6 |- |steering column | | DOOR TRIGGER|*1 |- |*2 | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|red/black |- |BCM, gray 24 pin plug *2 | |TRNK/HTCH RELEASE|black |+ |switch *4 | | TACHOMETER|*3 | |*3 | | SPEED SENSE| | | | | BRAKE WIRE|lt blue |+ |brake switch | | HORN TRIGGER|black |- |steering column | | WIPERS|green(L), purple(H) |+ |steering column | | LF WINDOW UP/DN|dk blue - brown |A |switch in center console | | RF WINDOW UP/DN|blue - brown |A |switch in center console | | LR WINDOW UP/DN|dk green - purple |A |switch in center console | | RR WINDOW UP/DN|lt green - purple |A |switch in center console | | SUN RF OPN/CLOSE|not recommended | | | | SUN ROOF LIMIT|not recommended | | | | RADIO 12V|orange |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|yellow |+ |radio | | RADIO ILLUMINATE|brown |+ |radio | | LF SPEAKER|tan - gray | |radio or amplifier *5 | | RF SPEAKER|lt green - dk green | |radio or amplifier *5 | | LR SPEAKER|brown - yellow | |radio or amplifier *5 | | RR SPEAKER|dk blue - lt blue | |radio or amplifier *5 |
Notes: NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The drivers door is gray/black. The other doors are black/white. Both wires are in the gray 24 pin plug at the BCM. Use both wires and diode isolate each. *2 The BCM is located above the glove box. *3 On the 4 cylinder models, use purple/white at the ignition module on the driver side of the motor. On the 6 cylinder models, at the ignition coils on top of the cylinder head on the drivers side of the motor, use any one of the three wires that is not pink or black. *4 Can also use black/white (+) at the BCM in the gray 24 pin plug. *5 The amplifier in under the driver side dash above the brake pedal. *6 Low beam is high current negative, must use relay. *7 The lt. green key sense wire at the steering column must see a ground during remote start to keep the "SERVICE
sounds like the amp is going into protect mode, Is it new? how are the subs wired, what are the voice coils config on subs. ground amp to chasis of car, shortedt wire possible...
1991-93 Saturn SC Stereo Information Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
if the factory wires are there, buy the aftermarket harness. the site provides no diagram for a mach system. But the wires s/b same at the amp.
1998 Ford Explorer Stereo Information Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
