Monitor Audio 1200G
Username: Philipt95148
Does anybody know anything about these speakers?
How old, how good, how much when new?
A local dealer is asking $800 for this, saying it is better than the RS6.
Any advice would be appreciated.
Thanks
philip
Username: Daniel_canada
Post Number: 62
"Better than" means what? How are they better? Did you listen to them? I have the Monitor Audio RS8. A google search turned up nada on the 1220Gs. Ask the dealer to set them up next to the RS6 as have a listen.
The 1200G is a used/trade-in model, I could not find anything on the net or B&W website either.
The dealer's pitch is that it was better made, more quality components at MSRP original at $2500, instead of the "budget" MSRP price of the RS6. His argument is that for roughly the same price, a used but higher quality made speaker is better.
He did let me compare the 1200G to the B&W 603 and it was very good. The 603 has a cleaner mid range but the 1200G goes deeper in bass and has a wider soundstage.
I will try to get him to demo the RS6 and 1200G side by side, thanks Dan.
Post Number: 67
?? Are those Monitor Audio or B&W speakers? You won't find B&W on the Monitor Audio site. Still, nothing from Google.
sorry, I meant MA site. I sent them an email, no reply so far.
What is your system Dan?
I am thinking of Rega Apollo, Prima Luna Prologue One and the RS6 or 1200G. Would this be a good combo? I listen to mainly classical, opera and female vocal.
Got info from Kevro, a MA dealer, that it was introduced in the early 90's and discontinued five years later. Couldn't be too successful if it was discontinued only 5 years after intro?
Post Number: 69
Things are cut if they don't sell, does not mean that they will sound "bad" to you.
My system:
NAD 162
NAD 272
NAD 521bee :-(
Monitor Audio RS8
I have visions of turtables dancing in my head. :-)
Post Number: 71
And the 422 tuner if you must know.
