New member Username: DelishagPost Number: 5 Registered: May-06 | I have a c**lsat 500 plat I checked the system info and this is what it says.... S/W Version-NORW-version 1.20p H/W Version : 1.10 Boot Version-2.10(09:14) CH Version: E005 Do I have the latest bin? If I need to download anything could you please explain where from & how? I'm loosing channels on 119 & I have no channels on bellvue, I entered new keys yesterday and it didnt fix either problem. I have the cable that hooks up to my pc, i just donot kow what to do or where to do it ect. Thank you very much for your help. |
New member Username: CybercubiPost Number: 9 Registered: Mar-06 | Delisha - Look here http://www.c**lsatupdate.com/new/main2.php?a=download&model=c**lsat (copy and paste into your address bar and remove and replace * appropriately) |
Bronze Member Username: HardrockstrikerPost Number: 62 Registered: Apr-06 | Delisha, 119 is down until a fix is put out. No fix is avail for c00lsat as of yet. Bev will require new keys from last day or so (if your autoroll is off), and with Bev there is no PPV or pr0n, but at least you'll have most channels there. |
New member Username: DelishagPost Number: 6 Registered: May-06 | thank you guys! should this fix or do i need to enter new keys manually? also how often does one have to check for updates on versions?? thanks again |
New member Username: DelishagPost Number: 7 Registered: May-06 | also...am i supposed to leave autoroll on for bell and dn |
