Will the Pansat bin work for fortec Lifetime ultra?
Username: Skyboy
Post Number: 33
I have a Fortec lifetime Ultra and had safely used the 2.73t chanceysand bin that was for pansat recivers with no problem.Does anyone know if the X-85BL_060609_277_au_api_ bin is safe for a no clone fortec?
Username: The_wank_artist
Post Number: 828
It is not safe for bins.
I'm may work or it may fry your receiver.
If your receiver was made after Aug 2004 then it will kill it.
Use it at your own risk.
It shouldn't be long before the clone safe bin is posted somewhere.
Username: Skyboy
Post Number: 35
Dang,my reciver's made in DEC 2004.Just my luck.
Thanks Tyler for the info.
Username: Bandulu_deh
Post Number: 10
where do you check when it was made?
Username: Skyboy
Post Number: 36
Mine has a DEC 2004 sticker on the rear of the unit.
Post Number: 841
I'm not saying to do it or not but here are the risks.
Some people can't wait for the proper bin and have been loading the 2500 Pansat bin. Some will find that it works, permanently or possibly only for a short time before it craps out or fries your receiver.
You can load it and see what happens, but I can't see it being more than a 24 hr wait for the new bin. I'd wait, but the choice is yours
Username: Skyboy
Post Number: 39
I respect your knowledge so I'll wait.
If a Fortec safe file comes out,would you tell me.I'll be on the look out and do like wise,you can even Hi-jack this post with it,lol.
Thanks in advance.
