ok i have a KENWOOD KR-V6060 i works great. heres the problem i recently moved. After i set up my home theater equipment it worked fine.A couple of hours later i went in to listen to some music and turned the reciever on.It turned itself off after like 2 seconds and the standby lite started flashing. is there anything i can do to fix this problem or am i screwed?
also i opened up the case and checked the internal fuse it was fine.
