Username: Junior22 Post Number: 1 Registered: Jun-06
Thursday, June 08, 2006 - 03:54 GMT Hey guys ... just wanted to ask your opinion on the system i plan on ordering very soon ... I was planning on doing 3 AA Assassin 12's amazing sq subs ... for anyone that is looking for an affordable woofer with amazing sound quality ... i have heard a friends single 12 set-up and it is very tight ... and sounds great with the music ... now my questions are this .. 3 12 each subs that have a a single 4 ohm voice coil .. can be wired to a load of around 1.5 correct? Therefore ... im planning on using an MB quart RAA1000 which does 1000x1 ohm .. which at 1.5 or so .. will do about 800 or so ... am i correct on this? thanks for the help guys ...
Alabama
U.S.
Post Number: 7550 Registered: Jul-05
Thursday, June 08, 2006 - 04:23 GMT it would be a 1.34 ohm load but close enough.lol and ur amp would do closer to 900-950.... good luck with that....
Username: Junior22 Post Number: 2 Registered: Jun-06
Thursday, June 08, 2006 - 04:35 GMT which would roughly give each sub 300-325 watts ... perfect .. right within the range of where AA states the subs are powered optimaly ... im hoping to get a little spl out these subs even though they are prodimentaly .. sq .. do u think theyll get loud? but retain the sound quality
Alabama
U.S.
Post Number: 7560 Registered: Jul-05
Thursday, June 08, 2006 - 04:39 GMT in the right enclosure they can be very loud....i would guess in the low to mid 140's in the right install
Username: Junior22 Post Number: 4 Registered: Jun-06
Thursday, June 08, 2006 - 05:23 GMT what kinda box u think chauncey ... i was thinking about 3.5 cuft
Alabama
U.S.
Post Number: 7588 Registered: Jul-05
Thursday, June 08, 2006 - 05:30 GMT honestly with a Fs-23.1 and a Qes-.41 i would run them ported so like a 6cuft box(2cuft per sub) tuned to 32hz-35hz depends on what ur listing style is...
Username: Junior22 Post Number: 6 Registered: Jun-06
Thursday, June 08, 2006 - 05:52 GMT honestly i dont think i room for that .. i have a hatchback ... what do u think i should run for a sealed enclosure
Alabama
U.S.
Post Number: 7600 Registered: Jul-05
Thursday, June 08, 2006 - 06:00 GMT 3.6 (1.2 per chamber) would work nice if ur gonna run them sealed, dont forget polyfill...
Username: Reef Post Number: 322 Registered: Oct-05
Thursday, June 08, 2006 - 06:06 GMT wat kinda car you got holler?
Username: Junior22 Post Number: 7 Registered: Jun-06
Thursday, June 08, 2006 - 06:33 GMT focus hatch ... fairly large hatch but nothing to big .. not enough for 6 cuft
