Runnin wire under the car?
Username: Langless28
Boston, MA
Post Number: 613
what stuff would i need to buy if running power wire under the car? i already posted this but i cant seem to find it under searching.
Los Angeles, CA USA
Post Number: 4030
use a pvc pipe under your car.
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 827
Just some conduit to shield it from heat and abrasion. And some gromets for the point where it enters and leaves the car.
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 598
why do you have to run it under your car?
Los Angeles, CA USA
Post Number: 4032
maybe he wants to do more than one run of 0 gauge to the back.
do you have another battery in the trunk bassfishing?
Username: Tweeker
Post Number: 237
i've never heard of anyone running wire under the car but if youre gonna do that that pv pipe was a good idea.
Boston, MA
Post Number: 614
im running wire under the car cus my 4ga wire barely fits in the trim panels and its partially exposed for like 1 inch towards the back. i like things looking really stock plus jeeps already have a gromet in the trunk on hte left side under the spare tire rack(where my amp is anyways). i got eko 0ga
