Load the new bin 271 to my pansat. But now, it has no singal on the T.V. I went to the menu then antenna on my remote. I found that the level is only 37% and quality is 0% what should I do? thanks
thanks Tyler, I did checked the DISEqC, and all the setting was good on there. Do you know if there is anything else to try before I realign the dish outside?
I'd go with checking the dish. To have level and quality one day and then not the next, it would be my guess that it's either the dish or the LNB. Does it look like it's moved, even slightly? and inch can make a huge difference in signal quality.
yea also, if he did a factory default reset before upgrade he might not have TP settings, or Lo freq. I use 11250 and my DISEqc is : DiSeqC 1 Echo9-IA 13 Dishnet 121 DiSeqC 2 Echo 7/Ku 119W, DiSeqC 3 Echo 8.6/Ku at 110W DiSeqc is nothing...at least i think so lol
OH yea mickey lee, if you are checking your satellite, be careful get a guide on where to point the thing....you can't just wing things, you should be able to find some sorta calculator to find the lat and long that you need....and don't break your neck
Is there anyone can help me find the Nagravision2 in my Vortex Pro 7700? I just bought the receiver, it only has Nagravision for 8 byte key code, not 16 byte key code. According to the description of the product, it should work exactly to Pansat 2500A. Thanks.
Sunny...this is NOT plug N play....GO READ!!!!...thats correct, it is a Pansat 2500 clone...so finding anything U need is very simple...LOOK anywhere..and its NOT an 8 byte key, U just haven't read ANYTHING about your receiver...Go read a few pansat 2500 simple setup guides and how to input the keys...Educate yourself and then upload the 275T bin and disable the autoroll.Any other DSS site has all the manuals, guides and bin files..here's 2 other sites
what are your settings for your satellite(s)? You should be able to GET channels but to watch them if so, you need a new key to access the channels...look around the forum they have been posted like a million times
