Bronze Member Username: KrisackermannPost Number: 13 Registered: May-06 | i know i ask alot of questions but it lets me knoe more on stereos soo heres it is.....i have a the kenwood KAC7252 or( http://cgi.ebay.com/KENWOOD-KAC-7252-1000-WATT-2-Ch-POWER-AMPLIFIER-NEW-AMP_W0QQ itemZ9731553947QQcategoryZ39734QQcmdZViewItem ) that there is a link...now i have a bass nob on it and it has the usual gain control but also has another nob...just wonderdin what is that nob and wat all does it do...also what do u think that nob should be at for best performance wit 2 type r's .....thanx for puttin up wit all my stupid q's??? |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1131 Registered: Jul-05 | i believe it has a bass boost and a low-pass filter. is that right? all the bass boost does is add distortion. also unless you have two of those amps its not enough power to run 2 type Rs. |
Bronze Member Username: KrisackermannPost Number: 15 Registered: May-06 | okk sooo if i get another one do u think that itll help.. also wat is a lowpass filter...i dont know? |
Silver Member Username: StnorrisEldridge, IA US Post Number: 288 Registered: Apr-06 | if that amp is 1000 rms like it says on the top, then it will work. lowpass filter is what frequencies you want your subs to play. if you set the frequency lower, lower notes will come through. and then vice versa. |
