Someone give me a hand porting this box
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 165
I'm building a ported box that's going to be 1.3 net cu. ft. and I'm trying to figure out my port dimensions to tune it to 32 hz, but it's frustrating as hell because every port calculator gives me different results. and why is it that if you increase the width and height of the port, the length increses also? shouldn't it be the other way around????
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 720
how tall and wide do u want the port to be...tell me this and i can give u the length
Username: Goatin
Ohio U.S.A
Post Number: 1341
What sub?
Whats the Xmax?
Whats the driver displacement?
Username: Hootz
Post Number: 166
WHOA, that took like 45 seconds. I'm shootin for about 1" high and about 16" wide. It's a 12" type r, so the xmax is 18mm I believe, and displacement is about .4 cu.ft. thanks guys.
Username: Thomas_g
NM
Post Number: 1060
Here man this is easier:
http://www.carstereo.com/help2/Articles.cfm?id=31
http://www.subwoofertools.com/forum/ported-box.asp
http://www.the12volt.com/caraudio/boxcalcs.asp
Post Number: 721
i got 21.09 inches long...if u go with the 1"x 16" port
Username: Rovin
Trinidad & T...
Post Number: 8052
here is a hand 4 u
Upload - lol !
use this calculator
http://www.carstereo.com/help/Articles.cfm?id=31
Username: Goatin
Ohio U.S.A
Post Number: 1342
http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=15&Dia=6&Xmax=18.2&V d=.071&NumW=1&Vb=1.3&Fb=32&Qts=.47&Vas=1.589160015&Fs=29&CE=1.5
Here ya go. :-)
Post Number: 722
lmao..now can i get a cookie rovin.....
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 161
Uhh, You cant use a 16x1 port can you? You don't maintain the 9:1 ratio. I would recommend a 16x2. Thats 8:1.
