New member Username: JeepgcPost Number: 6 Registered: May-06 | What gauge power and ground wire would you recommend to power an amp that will be powering 1 or 2 Type R's? |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 312 Registered: Jan-06 | depends on the rms the amp puts out. probly use 4 guage look on the12volt.com for exact wiring charts |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1436 Registered: Oct-05 | it doesnt matter at all on the subwoofers. the size of the amp depends on how big of guage u would use |
Gold Member Username: IlluminatorUSA Post Number: 3061 Registered: Apr-05 | http://www.electronixwarehouse.com/education/amplifiers/wiresize.htm |
New member Username: Ford150niteDelray Beach, Fl Westplam Post Number: 5 Registered: Jun-06 | 4 or 8 would be fine. |
Silver Member Username: James_gTN Post Number: 501 Registered: Jul-05 | If he's gonna be using an amp that will really push 2 Type-Rs, then 8 GA certainly will not be fine.... He's looking at a minimum of 1000w RMS. Using 8 GA from the battery would be stupid. |
