New member Username: Pohaku31586Post Number: 2 Registered: Dec-05 | I am replacing my Alpine Type-R SPR-17LP with Alpine Type-R SPR-17LS components. I am not sure where to mount the tweeters. Here are some idea's. http://chevytruckworld.tenmagazines.com/gallery/the97yuk/236288.jpg http://chevytruckworld.tenmagazines.com/gallery/the97yuk/236287.jpg or even this http://memimage.cardomain.net/member_images/5/web/197000-197999/197380_426_full. jpg http://memimage.cardomain.net/member_images/5/web/197000-197999/197380_428_full. jpg Thanks |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2304 Registered: Feb-05 | well, i wouldn't go with the second links. that looks like they will fire into the dash board... hook up the mid mounted where its going and hook up the tweeter un mounted. use some double sided tape and try both positions you have drawn out in the pics and see which you like best. looks like either would work, just depends on what you like. |
