Weird Problem
Username: Sgtibitoski
Clarkston, MI USA
Post Number: 20
All the sudden yesterday 3/4 my speakers cut out, but when I would turn out of a parking lot they would come on for a second then go out again, not sure what to do.
Username: Tjmutlow
Post Number: 2192
could be a wire touching ground somewhere...(speaker)
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2306
i had a friend who's car did that on the right side when he'd break or accelterate. it ended up being the factory wireing going to the speaker was bad. it was really brittle, so i guess it broke somewhere along the way. replaced it whith new wireing and its been fine ever since.
might wanna look for that too.
and if it is in fact grounding out, you better fix it quick before it burns up something like an internal amp if your powering off the HU.
