Silver Member Username: HootzSaskatoon, Saskatchewan Canada Post Number: 167 Registered: Oct-05 | Can someone with type R 12s (1222D or 1242D) check their spec sheet and tell me what the driver displacement is? I'm building a new box and my spec sheet is about 3 hours away, and alpine still hasn't updated their online manuals past the 2004 model. bunch of lazy b@stards. thanks. |
Gold Member Username: GoatinOhio U.S.A Post Number: 1368 Registered: Jan-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=37&Eh=17&Dia=6&Xmax=18.2&V d=.071&NumW=1&Vb=1.20&Fb=32&Qts=.47&Vas=1.589160015&Fs=29&CE=1.5 Here is all the specs, And a nifty little box maker. |
Gold Member Username: Thomas_gNM Post Number: 1173 Registered: Oct-05 | WWwazzzzzzzup Rave'n u straight or u a bronwn hater too????????? |
Gold Member Username: GoatinOhio U.S.A Post Number: 1369 Registered: Jan-06 | Hu? Don't be dumb. |
Silver Member Username: HootzSaskatoon, Saskatchewan Canada Post Number: 168 Registered: Oct-05 | Thanks rave'n, .071 cu.ft. I think is the added volume of the cone if you mount the sub inverted. I need the displacement which I think is somewhere around .3 cu.ft. but I can't remember for sure. Someone PLEASE check, I'm stalled till I can make the ports. Thanks a lot. |
Silver Member Username: HootzSaskatoon, Saskatchewan Canada Post Number: 169 Registered: Oct-05 | BUMP!!!!! |
Gold Member Username: RovinTrinidad & T... Post Number: 8074 Registered: Jul-05 | Rave'n is correct i have my spec sheet right here too ... |
