Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 396 Registered: Feb-06 | ok i got 3 sheets of wood usin 2 on my box for my car the box is goin 2 b 16hx34wx31d an its like about 8cubes goin 2 divide it in the middle goin with 2 12 cvrs or 2 12 type rs box is goin 2 have i dunno yet a 3inch slot port or 2inch tuned @ 24hz ya i no low but my bois box i did for 2 cvrs pounds @ 24hz an sounds pretty d@mn go0d far away i love it box will b facing in the car so i dunno about the travle part casue it tends 2 sux that way dunno how my car will sound since its dampin i just want them 2 pound so hard u hear it loud as he11 when i drive by an the amp i will b usin is the orion 2500d so 8cubes an 2 12s tuned low what ya think might b buildin thursday so everybodys input will b ko0l |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 403 Registered: Feb-06 | bump |
Silver Member Username: ReloadedMebane, NC U.S.A Post Number: 170 Registered: Dec-05 | you seem to be having the same problem as me |
