Alpine Type S vs. Type R Components
Username: Camaro155mph
Post Number: 349
Are the Type R components worth an extra $30 for over the type S components? The Type S are 50 RMS and the Type R are 70 RMS. My amp pushes 55 RMS to each speaker... opinions???
Username: Alteraudiousa
Concord
Post Number: 858
Type S will better suit your needs and can be less of a pain to install but the Type R's will have a much better midbas given the install is good.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 216
My type R's have great mid-bass but with the amp you're using I would go with the S's
Username: Adddisorder
West palm, Florida
Post Number: 316
i second what andrew says type r are better but that is only if you can give them alot more power then 55rms
Post Number: 358
So any speaker over 55 RMS is useless to buy with the amp I have???
