TC Sounds...new site.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2991
TC sounds just updated their site...they are releasing a few subs that look pretty darn good.
http://www.tcsounds.com
I like this one:
http://www.tcsounds.com.unixweb-7.nethere.net/tc3000.htm
not at bad buy at $400+ship
38mm xmax
3" quad 1ohm VC's
Fs 19hz
TC3HP motor
Username: Rovin
Trinidad & T...
Post Number: 8054
that sub looks mighty impressive ^^^ .....
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1114
the LMS-4000 looks like an amazing sq sub. pretty expensive but could be well worth it.
Username: J_baby15
Kentucky
Post Number: 355
How do those subs sound?? Has anyone heard them?
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 858
can i run 1ohm on the quad 1ohm vc sub....cuz i might just get 1...tc-3000...cant find whut it will wire to...plus im at school
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 807
Yes you can run it at 1 ohm if it is quad 1 ohm. At the minimum I would run it off a kx1200.1. I'm sure they are very underated. I would try to give them around 1500-1800 rms.
Username: Basshead86
Google is your Friend, FL
Post Number: 3655
Very impressive stuff.:-)
