Building a ported box
Username: Bretzy1990
Springfield, Il U.S.
Post Number: 71
i think i might use a round port. where in the box would u reccomend placing the round pipe on the box - and what do u place on the pipe to mount it flush on the box?
Username: Thomas_g
NM
Post Number: 1126
put tha port wherever u want.
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 540
any where as long as it meets the spesifications
Post Number: 72
is there some kind of sleeve you can mount the port to the box with?
Post Number: 73
bump
Username: Lexuscoop
Post Number: 542
just draw a circle and get a jig saw? whats a sleeve mount going to do?
Post Number: 74
well im just wandering do u like glue it in or just set in there. i dont want the port falling out. but i want to be able to make different tunings for it so i can make interchangable ports.
Username: Lexuscoop
Post Number: 544
make ti a tight fit and screw it in so you can take them in and out
Username: Thomas_g
NM
Post Number: 1135
lol ya and make a whole with like a hammer and screwdriver where ur cuttin so u can fit the jiggi inside. Try to make the hole a lil smaller than what u planned on so the port can fit securely then glue it and caulk it.
Username: Thomas_g
NM
Post Number: 1136
o and id recommend u use 4" pvc just to be on the safe side of not getting port noise and then sandpaper the pointy ends B4 u displace tha port.
Username: Lexuscoop
Post Number: 545
TJ, he wants interchanable ports...
Username: Rovin
Trinidad & T...
Post Number: 8059
um ^^^ - the thing with 4" pipe ports it requires ur box be built deep (if u dont want a L shaped pipe port)
so use the calculator on www.the12volt.com 2 be sure u can fit a 4" , 3" is the standard though .
I snug cut the hole & use silicone sealant it mines & it holds securely
btw - i like my tuning around 32-35hz ......
Username: Thomas_g
NM
Post Number: 1138
o ma bad peepz. FU*k itz hot heat stroke!!!
Username: Lexuscoop
Post Number: 546
PLEASE YOU DON'T KNOW WHAT HOT IS TILL YOU SIT OUT SIDE FOR 3 HOURS IN PHX IN THE MIDDLE OH THE SUMMER!!!!! LOL!!!! but its a dry heat LOL!!!
Username: Thomas_g
NM
Post Number: 1139
ya i had to make my port like 15.5 inches long with 4" pvc buts its all good it fet. I alwayz had bad luck with 3" no matter wut i did id get port noise, so if u go with 3" good luck. And i honestly think in my opinion 4" pvc rather than 3" pvc hits harder and deeper for my cvr.IMO
Username: Thomas_g
NM
Post Number: 1140
I dont have air conditioning and im roastin my azz off!lol
Username: Rovin
Trinidad & T...
Post Number: 8061
"""the thing with 4" pipe ports it requires ur box be built deep (if u dont want a L shaped pipe port)"""
what i should also had added is that with larger sized diameter ports the ports have 2 be longer so u need 2 see it ur box dimentions design/shape can accomodate it .....
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 756
try livin in f*ckin florida during the summer...humid moist heat...the f*ckin worst..u think u have it badd....hahaha u dont no the word heat nigga.....
Username: Rovin
Trinidad & T...
Post Number: 8063
well then next best solution is making ur own square or rectangle port using
http://www.carstereo.com/help/Articles.cfm?id=31 ....
Username: Lexuscoop
Post Number: 548
i agree drivin, i was there for vavaction... it was horible LOL
Username: Thomas_g
NM
Post Number: 1143
Hey that wordz not appropiate coming out of a cubanos mouth.
Post Number: 757
damn tj got beef...bro i hope u no im always joking except for the heat..but bro have a sense of humor.......racist dawg racist
Post Number: 759
didnt bump
Username: Thomas_g
NM
Post Number: 1147
lol ya i know im kidin too my brown carnalito. Letz not fill up forums again with BS.
