Bronze Member Username: GangstafertPost Number: 92 Registered: May-06 | what kind of capacitor should i get and what do exactly do they do? |
Gold Member Username: FandimReno, Nevada United State... Post Number: 1113 Registered: Jun-05 | http://www.wickedcases.com/caraudio/capacitors.html |
Bronze Member Username: GangstafertPost Number: 94 Registered: May-06 | so if i get a HO alt do i still need a capacitor and if so which kind would you recomend(capacitor)? |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 869 Registered: Mar-04 | if your alt is large enough to power your system the benefit of a cap is minimal at best. If you want one there's no brand or type that's really any better than another. The only spec that really matters is ESR. It should be below .002 ohms. If it's not listed, chances are it's not low enough. What amp(s) are you installing? |
Bronze Member Username: GangstafertPost Number: 100 Registered: May-06 | not sure yet but something around 1400 rms@1ohm to push my 2 arsenal 12's. |
