Stll asking for keys and ppv solution? Here is the solution
Username: Watzupwitu
For all those that are still asking for keys and fixes for the ppv channels, I got the solution for you. Go up to your roof, disconnect the dish, shine it up real nice and stick it up ur A*SS.
Actually, for the sake of those in this forum that will try anything, DO NOT STICK THE DISH UP UR A*SS.
Username: Comet2comet
Post Number: 8
I lika da post tony, ia somatimes weesh dat dos people cana maka da read
Username: Hybridfay
Mississauga, Ontario Canada
Post Number: 28
tony u seems to me going pretty fast riding on ur AS*S*.
Username: Mestre1966
ok people Listen once and for all thers NO key change.
DN as made same changes but NOT on the keys.
U can still use the last keys.
In may case i have bin 148c (pansat 2700A)
turn Off all the autorolls and use the folowing keys on NG2
N 0101 00:
E8 70 B0 0A 8E OA 3D C5
F3 59 C3 5F 1A DA 19 5C
N 0101 01:
71 9C 60 71 04 C1 39 AE
88 FF F0 5E D2 4C F3 FC
I recomend to make a blind scan, turn off the autorolls and then put the keys
Some times the screen will come up with a "updating channels" if that happends just go back, see if the keys are the same and if the autorolls are off
if you get an "waiting for picture" go back and check all again.
My pansat @ 121 its working fine for the last 4 hours now, but without PPV or all those nasty channels (lol) that you guys want. Im my case i just was worried about my Science Channel, History, Discovery, and some Starz and HBO :-) and im still geting those.
Have fun!!!
