Bronze Member Username: New07ftaPost Number: 40 Registered: Apr-06 | anyone else is missing those ppv's on those transponders. i did manual scan but no ppv channels. |
Silver Member Username: The_wank_artistPost Number: 637 Registered: Feb-06 | Which channels? And did you check either of these info pages. http://www.lyngsat*com/packages/dish110.html 504, 508, 518, 522 and 539 are all still listed at 12297 L, tp 6 |
New member Username: Digi6800Post Number: 2 Registered: Mar-06 | I only got 2 ppv (511 and 519), the rest is missing. I tried upgrade the bin and did blind scan but still no help. What did I do wrong? or What should I do? Please help! |
Bronze Member Username: LetmeonPost Number: 21 Registered: Mar-06 | 119 has only a few PPVs and 511, 519 are on 119 sat. 110 sat has the rest. So your dish should pickup 110 AND 119 .... |
Bronze Member Username: New07ftaPost Number: 41 Registered: Apr-06 | i'll scan that tp today, thanks for the help |
New member Username: Digi6800Post Number: 3 Registered: Mar-06 | I did scan both 110 and 119 sat. |
Bronze Member Username: LetmeonPost Number: 22 Registered: Mar-06 | Did U do a BLIND SCAN ? That gets different frquencies that could have changed. I always do blind scan. |
New member Username: Digi6800Post Number: 4 Registered: Mar-06 | I did couple times on both 110 and 119 but still only can get 3 PPV channels. The rest are missing or no signal. I tried to load someone channel list but the same. Any ideas? Thanks for the help! |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 604 Registered: May-06 | Digiwave try restore factory settings set your receiver, scan. |
New member Username: PansatmanBristol, Va USA Post Number: 6 Registered: Jun-06 | wat do u do help!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
