Help with resin
Los Angeles, CA USA
Post Number: 3996
i have some questions about resin for those of you who have experiences or know about using resin.
can i buy it at home depot or lowes?
do i need to mix it with something before i apply it on to wood or do i just brush it on straight out of the can?
i want to resin the inside of the box so it will be stronger and smoother. thanks in advance.
Username: James1115
Ct
Post Number: 5891
you need to mix it with an accellerator but you have to work quick Chad because it dries pretty quick. The hotter the day the faster it dries.
Username: Bobimpact
Post Number: 17
Polyester resins need a catalyst called MEKP (methyl ethyl ketone peroxide) You can lengthen dry time by putting less catalyst into your resin. Also, be sure that you buy a high grade of resin, cheap resins can shrink and expand a great deal. On a 75 degree day you can pretty much count on a 1 fl. oz. of resin to 1cc of MEKP ratio.
Los Angeles, CA USA
Post Number: 4000
alright thanks guys. its alot harder than i thought. all that mixing of chemicals and stuff. lol.
Username: Adddisorder
West palm, Florida
Post Number: 290
chad at a surf shop you can get some stuff i foget what its called but it comes in a little black bottle, and you dont have to mix anything, just pour it and smooth it out with a little foam roller from homedepot. it is very stong cures very fast and is great stuff, iv used it a few times for other stuff.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2979
you can get resin at Wal-mart...that is where i get mine.
here is a lil tip...dont paint the resin on to the walls of your box. pour it on them, it will give you a much smoother coat.
Los Angeles, CA USA
Post Number: 4003
thanks again guys.
marshall i see you have done it already. in your opinion does it help improve the sound?
Username: Extrmndor3
Chicago, Ill Us
Post Number: 917
http://web.njit.edu/~cas1383/proj/main/
Username: Thomas_g
NM
Post Number: 940
Resin wuts resin peeps??
West palm, Florida
Post Number: 300
resin is the stuff you find in your bowl after smoking a big fat nug tj :-)
but in this case its like a fiberglass but without the cloth and stuff...
Los Angeles, CA USA
Post Number: 4012
rofl mat. you are right.
Username: Thomas_g
NM
Post Number: 953
lol mat dats da only resin i know of!
Username: Thomas_g
NM
Post Number: 954
I was pretty sure it wasnt tha kind im talkin bout.
Username: Fandim
Reno, Nevada United State...
Post Number: 1085
That box would smell good. Just dont get pulled over.. Cops seem to dislike that aroma. ;)
Username: Doom
Post Number: 20
Where in walmart can you find resin? Not the aromatic kind.lol
