New member Username: AkamigsPost Number: 7 Registered: Apr-06 | i need component and full-range speakers that can handle around 50 watts rms each. price is not an issue. any suggestions? |
Bronze Member Username: VirulentvPost Number: 49 Registered: Mar-04 | anything by Rainbow or Dynaudio |
Bronze Member Username: BigsimPost Number: 52 Registered: Jan-06 | Rainbow Reference 3-ways run for $10000 a set... |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6828 Registered: Jul-05 | where. there not that much |
Bronze Member Username: BigsimPost Number: 54 Registered: Jan-06 | "50 watts rms each" Should read before I post I spose... |
Bronze Member Username: BigsimPost Number: 55 Registered: Jan-06 | http://caraudiosecurity.com/shop/product/products_id/3999.html |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6834 Registered: Jul-05 | of course..Everything is more expensive oversea's, if u bought those in the states there no where near that much |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6836 Registered: Jul-05 | read this, have fun https://www.ecoustics.com/electronics/forum/car-audio/217405.html |
Gold Member Username: Jonathan_fGA USA Post Number: 5966 Registered: May-04 | Those Rainbows are $10,000 USD. Good luck finding any Rainbows in the US now, though. Alumapro isn't a distributor anymore. 2 ways are $7000. |
New member Username: AkamigsPost Number: 10 Registered: Apr-06 | remember im only looking for 50 watts rms each. i wasnt expecting to pay thousands of dollars for 50 rms. lets keep it under $300. |
Bronze Member Username: VirulentvPost Number: 51 Registered: Mar-04 | Anybody knows why ALUMAPRO isnt a distributor anymore? Jonathan? |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 1995 Registered: Feb-05 | i always find it funny when someone makes a post saying money doesn't matter, best i can get for any cost. then we throw the 10 grand rainbows, then they throw up a few hundred dollar price. |
Gold Member Username: GavincummNew York USA Post Number: 1109 Registered: Feb-05 | LOL...I do the same thing over in home audio... "whats the best speakers out there...cost no object." um... How about Wilson Audio WAMM's? (200,000) people quickly change their tune when they see that sum. Mind you, the WAMM is no longer made, production has been stopped on that model for roughly 6 months, but I just love dropping that number on neophites :-) |
Bronze Member Username: JohammbassCork, Cork Ireland Post Number: 18 Registered: May-06 | And WHY only 50W RMS??? If money is no problem you could get a bigger amp. Rainbow's are worse then they cost. Flagship Genesis component set sounds better, made by Scan Speak and yes made for Genesis only unlike Alpine - just took some existing Scan Speak speakers and put Alpine on it. For Genesis it was a long, painful try this, then try that process |
New member Username: MuchlouderthanuUSA Post Number: 3 Registered: Jun-06 | Get some MB Quart QSDs. You cant go wrong with these. They are loud as hell and will run you about 1200 dollars. I have these in my coupe and they sound amazing. ZERO distortion. |
