Yes, easily. Just make sure all your amps are set to the same voltage, and be extremely sparing with the volume control. you'll clip the hell out of it even if it's set to it's lowest sensitivity, if you turn the volume up too much.
I plan on running 1K class a/b watts RMS. I'm going to upgrade the "Big 3" and replace my battery with a red top. My alternator is 105 amps,will that be ok?
