Sony camera/MAC OS X
Username: Figmentaria
I have a sony handycam and I'm trying to get my video into my computer to make a DVD. The problem is that they dont have Image Mixer for OS X and the program I do have cant stream from my USB port. Is there a program that will read the video from my USB port so I can import the video?
Username: Beeners
Raleigh, NC USA
What model Handycam do you have?
My older Sony Handycam has both USB and firewire (or iLink as Sony likes to call it). The socket on the Handycam is labeled "DV IN/OUT". iMovie should be able to import from firewire. Needs a firewire cable with the small square-ish plug on one end and the regular connector for your Mac on the other.
If the Handycam has nothing but USB, you'll need a capture dongle for your Mac. You can find these for <$100.
Good Luck
